Old 05-26-2006, 04:31 PM   #1
88 MARK3
88 MARK3 is on a distinguished road
Default Targa Problem
Another problem!
My Mark3 turbo has a T-Roof.
But when it rains, or when I wash my car, there is water coming out of my reading lamps/lights. I have tried to find out where the water originally is leaking in but I can't find it. I am thinking it is the targa but it could be the windsheild seals. Anyone have the same problem and can help me out a little? The previous owner did a pretty good job keeping the mechanical stuff in good shape but body needs some work.
And also, where can I find the tool that opens up the targa? Not sure if the previous owner have givin me that. Is there a special tool that I need?
88 MARK3 is offline   Reply With Quote
Old 05-26-2006, 05:31 PM   #2
ddmcse
ddmcse's Avatar
a regular allen type wrench will work you don't have to have the toyota wrench
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-29-2006, 03:26 PM   #3
88 MARK3
Thanks....I can take off the top now.
But what about the water leak?
I have found out that my hatch leaks too.
Would I be able to replace all the window, T-top, Door seals at a auto glass shop? Or do I have to go back to toyota?
Old 05-30-2006, 01:36 AM   #4
burton51m
burton51m's Avatar
Cool
they'll do it for you...to find out where your leak(s) are-
-turn your car on with the A/C on running on high
-shut all your windows and make sure your t top is on and locked
-get out and shut the door with your A/C still running
-take a smoke machine or some kind of smoke and go around the door seals and t top with the smoke. where you see the smoke blowing (or being pushed) away from the car is where your leak is.
if you find a leak (where the smoke was pushed away ) you need to replace your seals.
any window place will order them for u
Old 05-30-2006, 03:10 PM   #5
theWeezL
theWeezL's Avatar
wow, thats a pretty damn cool idea! obviously you would have to have a pretty calm environment like a closed up garage but it seems to me that it would work.
____________
Old 05-31-2006, 03:51 PM   #6
88 MARK3
Great idea! Thanks alot. Great help!
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Nissan Sentra Tranny problem. redmaro Off Topic Forum 2 11-28-2006 01:58 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
