Old 03-15-2006, 08:49 PM   #1
mnitrice
mnitrice is on a distinguished road
Question 94 TT head gasket problems?
Hi I was just wondering if these cars have head gasket problems like the trucks with the 3.0 have. Thanks Was there ever a recall like the trucks?
mnitrice is offline   Reply With Quote
Old 03-16-2006, 04:43 AM   #2
94TT
94TT's Avatar
94TT is on a distinguished road
Default No Recalls on the Twin Turbo
I Have driven my supra for over 110,000 miles and it just started to leak a tiny bit of oil from the head gasket.
94TT is offline   Reply With Quote
Old 12-02-2006, 07:21 PM   #3
94TT
94TT's Avatar
Default Leaking Oil?
My 94 Supra TT has been leaking a little oil at the Valve cover for some time.
When I took off the valve covers to replace the gaskets around 130,000 miles I discovered the valve covers where just loose on the inside corner nuts.
I replaced the gaskets anyway and put it all back together. Be sure and order new valve cover breather (crossover) hoses before you start because they are usually brittle and your local Toyota dealer does not stock them. Try Champion Toyota 800-327-2087 ask for Jeff.
Old 12-27-2006, 08:18 PM   #4
Nope, the MK4 Supra Turbo's engine (the 2jz-gte) is not prone to headgasket failure.
