Old 01-30-2006, 12:39 AM   #1
Blsadler
Blsadler is on a distinguished road
Default New supra owner
I just bought an 89 supra turbo. I have read that these models tend to blow head gaskets at around 90k. the car runs smooth and there are no indications that there are any problems. I am considering changing out the head gasket as a preemptive strike. I am not a mechanic but I think that it may be something I can handle. Not sure what to do yet, I hate to tear it apart when it runs good.
It is reliable imfo that the headgaskets are unreliable.
Blsadler is offline   Reply With Quote
Old 01-30-2006, 01:23 AM   #2
TxSpeedBoy
TxSpeedBoy's Avatar
TxSpeedBoy is on a distinguished road
yes, it is true.
http://photos.dylanwiggins.com/thumbnails.php?album=84
Definatly go with a metal head gasket. Good luck.
Supra Project 06... 1987 Turbo.
18" Enkei RS5. K&N Filter. Magnaflow custom exhaust.
"I got a pair of subs for my girlfriend...Good traid huh?!
TxSpeedBoy is offline   Reply With Quote
Old 02-01-2006, 01:55 AM   #3
mrnickleye
mrnickleye's Avatar
If it were me (and it was 3 years ago when I got my '89), I would drive it for awhile to see how it is. I always change 'all' the fluids within the 1st month. (My gasket started leaking last May, so I did a valve job, resurfaced the head, hand-cleaned the block, and reassembled it. Runs great.)
If it runs good, and no coolant leaks, or having to add collant, then flush out the system and reload with antifreeze, 50/50 mixture. I would go ahead and change all hoses too. And the rad. cap.
DON'T use a metal headgasket unless you are gonna have the block resurfaced, along with the head resurfacing. The metal gasket is very 'unforgiving', and will not seal correctly. Both surfaces must be very fine.
A regular headgasket will sqeeze down and compensate for some little irregularities in the surfaces.
They accepted cause of the gasket failure is the fact that the factory only torqued the bolts to 58 ftlbs. They should be 72 ftlbs.
This seems to resolve the problem.
Old 02-05-2006, 02:41 AM   #4
Blsadler
thanx for the input
New Supra OWNER. VooDoo MKIII Supra 4 03-12-2008 12:24 AM
New supra owner (not running) here What to do next Gengus MKIII Supra 1 11-12-2007 03:46 AM
Possible supra owner questions! Zanark MKIII Supra 2 08-24-2007 06:01 AM
New to this forum(not a supra owner though) Supra spotted in tucson. z33 DaRkNeSs Off Topic Forum 5 08-28-2006 11:16 AM
