Old 01-17-2006, 05:25 AM   #1
TxSpeedBoy
TxSpeedBoy's Avatar
TxSpeedBoy is on a distinguished road
Post Changing BHG?!
I am concidering changing out my bhg. But I was just wondering on the degree of dificulty for this task? What size head gasket should I get? Any one care to post a step-by-step guide to changing the head gasket on turbo charged MKlll? Besides...it's just bults and screws....right?
Supra Project 06... 1987 Turbo.
18" Enkei RS5. K&N Filter. Magnaflow custom exhaust.
"I got a pair of subs for my girlfriend...Good traid huh?!
TxSpeedBoy is offline   Reply With Quote
Old 01-17-2006, 05:53 AM   #2
joel w
joel w's Avatar
download the free repair manual, it also has a step by step how to i think?
IM too lazy, but here is a write up that dylan wiggins did, its pretty funny too.
http://photos.dylanwiggins.com/thumbnails.php?album=84
as for what headgasket to use, depends on what boost and mods you may have in mind?
yup nuts and bolts ,
Old 01-17-2006, 07:09 AM   #3
TxSpeedBoy
TxSpeedBoy's Avatar
Riiiigggghhhhht.... well, that doesn't look too hard! I am going to try it, but I will probably regret it about half way through it. Oh well! Wish me luck guys. I am going to attempt the famed bhg replacment as soon as I get a chance...and the guts! Still need to know what size hg though. I am thinking that this engine won't see anything above stick horse power. I am saving all the goodies for the engine on the stand. So for a stock replacment, what size?
Thanks alot Joel Williams, couldn't have asked for anything better.
Old 01-17-2006, 07:28 AM   #4
joel w
joel w's Avatar
i replaced mine with a new toyota gasket, correct me if im wrong here people, but the thickness of the gasket depends on how much material you remove from the block and head surfaces to bring it back to stock compresssion,, and or,,, you can get a thicker gasket to lower the compression ratios for higher boost potential.
some metal head gaskets are good, but require specific surfaces for proper sealing against the head and block...
also if i were you, id also call around and find a good machine shop to look at your head when you get it off to check for warpage. valve adjustment and or lapping the valves even valve guide seals ecetra.. if needed or whatever..
PS;ask if them have adjusted bucket shim valves before, if they say what? keep calling around..
http://www.supra.co.nz/87tsrm/
http://groundsky.co.nz/techinfo/TSRM/
http://groundsky.co.nz/techinfo/TSRM/03_EM.pdf
Old 01-17-2006, 07:31 AM   #5
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
Default Take pics & label!
There is lots of info on this out there, but I will tell you what you may not find.
If you have a digital camera, take lots of pics with hoses labeled with tape.
Label things that you may lose track of.
That is how I do things, and it will actually save you time, not cost you time in the long run!
Others don't do this, but some may need the extra help/guidance because they may not have had their eyes on 7M's for extended periods of time, unlike other 7M gear heads
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
Old 01-17-2006, 07:36 AM   #6
joel w
joel w's Avatar
tonys right, sharpie ink pen and a box of baggies for me too..
Old 01-17-2006, 07:51 AM   #7
TxSpeedBoy
TxSpeedBoy's Avatar
Sweet, that will help out alot. Knowing a seasoned professional like me , I wouldn't have even thought of that. That will help me out alot guys. Thanks for all the input. Yal' have saved me alot of headaches!
Old 01-17-2006, 08:49 AM   #8
Strannik
Strannik is on a distinguished road
www.supras.nl has a guide with pics on rebuilding a head.
Strannik is offline   Reply With Quote
changing fuel filter 3.0trd MKIII Supra 9 04-22-2008 10:47 PM
Changing LSD oil. redmaro MKIII Supra 8 04-28-2007 11:13 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
changing out ring gear Burn N' Up MKIII Supra 0 08-30-2006 07:09 PM
Changing stock air intake. lifesnotfair Non-Generation Specific Questions 7 01-02-2006 08:50 AM
