Old 12-14-2005, 01:31 PM   #11
scruffboy
scruffboy's Avatar
Default RE: Hood
Thanks to everyone who responded, I've checked the pics, snaked a drop light into the comparment, took off grilles and turnsignals but still can't get this bi*ch open (the 15o weather here in Jersey ain't makin it easier. I made an appointment at body shop I know. When (if) he gets it open I am going to study it with a friggin microscope so this will never happen again. Also, I am going to study gas cap door cable in case something happens to that. I would suggest to all you supra owners to look into these things, as these cars run real well, but they are old and some things just don't last for ever, so you have to expect things to go now and then. Again, thank you everyone, especially Joel who sent close-up pics, I will pass them on to mechanic.
James in NJ
Old 12-14-2005, 07:05 PM   #12
j3pz
its sad that something so small can cause such trouble
Old 12-14-2005, 07:12 PM   #13
joel w
joel w's Avatar
all i can add is that you need to go into it from the side in between the IC and the radiator cavity..the latch is at the top..
Old 12-14-2005, 11:41 PM   #14
mrnickleye
mrnickleye's Avatar
OK...but you must give Boromire credit for that line, hiking in the snow, when he picks up the ring after frodo dropped, from "Fellowship of the Ring".
Also...I was thinking that I will go look at my cables to have a plan if it happens to me.
Old 01-09-2006, 12:29 AM   #15
Justin727
Justin727 is on a distinguished road
Originally Posted by SKILMATIC
Wow, this is a dilemna. Its sounds easy but its really not. The only thing I can think of is you are going to have to take off your quarter panels in the front and romove the hood. Unless you can get it to unclock you are going to have to do this.
you have to open the hood to remove the panels. If you reach under the front bumper to the latch you might be able to push the spring and it should pop open.
Justin727 is offline   Reply With Quote
Hood release cable catawalks Non-Generation Specific Questions 11 04-24-2007 03:04 AM
HELP!!! My Hood is stuck closed!! opeth_07 Exterior , Interior, and Detailing 6 07-31-2006 06:02 PM
HELP!!! My Hood is stuck closed!! opeth_07 MKIII Supra 4 03-30-2006 12:55 PM
what do you use to hood open your hood? j3pz Off Topic Forum 4 01-23-2006 09:16 AM
Got Hood Open!!!!! scruffboy Non-Generation Specific Questions 2 12-20-2005 02:03 AM
