Old 12-07-2005, 12:06 PM   #1
scruffboy
scruffboy's Avatar
Unhappy Please Help Me Pass Emissions
I recently went for inspection here in New Jersey and failed for emissions. I don't have the printout with me, but I believe I passed the NOx but failed for High Carbons and one other thing (not sure). I don't want to get ripped off so can someone set me in the right direction. The car runs great and I just did a tune-up (plugs, wires, rotor, fuel filter, air filter, etc.), though I did notice a little oil on one pair of the plugs. I also do regular oil changes using castrol syntech. I also use high octane fuel (92). I know nothing about the O2 sensor but a mechanic I stopped at on the way home said something about maybe getting too much air in the mixture? I don't think its the charcoal cannister, as I don't smell fuel in the interior. The mechanic I saw said it may cost about $250.00 (ballpark figure), plus 75 for the re-inspection fee. Can anyone help me. PLEASE!
Sincerely,
James
Old 12-07-2005, 02:46 PM   #2
SupraMan1784
james did you go to the inspection station in paramus?
Now: Saving for an MKIV
Broken Rides:
Old 12-07-2005, 02:55 PM   #3
scruffboy
scruffboy's Avatar
Default Re: Inspection
No, I went to Secaucus as I heard they were O.K. also.
James
Old 12-07-2005, 03:06 PM   #4
SupraMan1784
those guys dint pass you? hmm...well im tellin you man make that trek to paramus...or talk to nickeleye...i think he used to work with emissions
Broken Rides:
Old 12-08-2005, 03:52 AM   #5
Wink
If you can get the info (#'s) off the 'failed' report, I can steer you to what is wrong. I manage a smog shop here in So. Cal. (the most anal smog control co. in the world)
Old 12-08-2005, 01:54 PM   #6
SupraMan1784
i knew it...i knew he was gonna post on this thread sometime...the question was when
Broken Rides:
Old 12-09-2005, 12:56 AM   #7
j3pz
i got a quick q. if you dont have they egr valve, have it blocked off like the jdms will you pass?
Old 12-09-2005, 03:13 AM   #8
jfunez
jfunez's Avatar
money talks... pull the manager to the side and softly speak to him er. brive him...that'l work...hehe...
worked in houston for me...
Old 12-09-2005, 03:41 AM   #9
If the smog tech doesn't notice (or care) that the EGR is missing.....
You should have a pre-test done to see where your at. Make sure they don't send the info into the state !!!
You don't want to go get tested 'blind', then be so far over that you become a "Gross Polluter".
With out the EGR (or plugged passages), the NOx will probably be too high. If your cat is working, and NOx is the only failure part of the test, and its only about 100 or so PPMs over the limit, you can retard the timing back to 5*, or 0* for the test. This will lower the NOx.
The CO% and HCs must already measure low.
This is why for smog test areas, I recommend leaving the EGR alone. If your engine is working properly, it won't hinder power. If you just must 'clean up the engine bay', then save all the parts to put back on for the test. If you just 'can't stand egr', then you can just pull the vacuum line on the valve and stick a golf tee in the hose.
Old 12-09-2005, 03:20 PM   #10
j3pz
well its just not worht the trouble then is it
code 52 knock sensor can't pass emissions hotrod705 Non-Generation Specific Questions 12 08-18-2009 07:44 AM
emissions FYI ddmcse MKIII Supra 0 02-01-2008 12:34 PM
Went through Emissions today.... IHateHacks MKIII Supra 32 07-03-2007 07:31 PM
Emissions drmmr15 MKIII Supra 1 01-19-2007 04:09 PM
Emissions? Luvs2slide MKIII Supra 3 06-03-2006 11:55 AM
