Old 10-18-2005, 06:43 PM   #1
aznwaterboy
aznwaterboy is on a distinguished road
Default 1jz-gte smog test
does anyone know what i'm gonna have to do to get the 1jz-gte to get smog passed in calif? i'm considering right now if i want a 7mgte or a 1jzgte into my car, 90 supra 7mge w/110k miles
aznwaterboy is offline   Reply With Quote
Old 10-19-2005, 03:14 PM   #2
SupraMan1784
if you know somebody that can get you a "passed" sticker...you should be ok, dont go to state inspection stations...i know a friend that does private smog tests...well he owns his own shop and he knows i have a 1jz..so he just made sure i wasnt killing anyone...my car actually passes nj smog tests, but i know inspection wont pass me since its not the factory motor..so my boy passed my car...rightfully
Now: Saving for an MKIV
Broken Rides:
Old 10-21-2005, 12:40 AM   #3
Here in Calif. you can only replace the motor with one that was offered for that model. You can go newer year (89 car, 91 motor). 7mge N/A to 7mgte turbo is OK.
Going to a different type motor might get by the smog test guy,
if it runs really good,
everything looks like factory under the hood,
(remove any stickers that give engine ID, like 7mge, etc.)
no check light on or codes,
timing set to original spec (10* ?),
all hoses properly connected,
new gas cap,
egr in place and working
evap system in place and working,
and it passes the tailpipe test.
(PS...I manage a smog shop)
Old 10-21-2005, 01:15 PM   #4
SupraMan1784
haha i put a sticker on my 1jz that said 7mgte...it passed inspection the first time...but then it melted off on my way home....in nj..its the same type of thing u can put in a motor designated for that car...either that year or newer..cant be older, and u cant have motors that were never in that car.. or never meant for it...like a 1jz in an mk3 or an sr20 in a 240...stuff like that, but i can swap a gsr motor into a civic, i dunno the laws here are messed up
Broken Rides:
Old 10-23-2005, 08:10 PM   #5
aznwaterboy
Default why do we need titles
hmm where did u get the sticker for the 7mgte when u had the 1jz in ur car? my friend did that to his crx, got a b18 in there but had a dif sticker. also anyone know how much an illegal smog would cost in CA?
Old 10-24-2005, 06:02 AM   #6
Unhappy
Since the fine is $10,000, and a license probation, it's pretty hard to find someone you don't already know to do an illegal for you.
I see many, many engines come thru the shop that have no sticker to tell us what it is. I doubt the technician would know the difference, as long as everything looked good, and in its proper place.
Make sure its running great, new gas cap, etc. You can always have a 'pre-test' done first. Pre-tests are not official, and are not held against you if it does not pass. If the tech says, "hey, looks like you'll pass", then go ahead and run the real test, cause he's been fooled with engine swap.
And...Maybe you can make a sticker by getting a picture of one off the internet, then printing it on a piece of aluminum, then glue it on the timing cover.
Old 10-24-2005, 01:43 PM   #7
SupraMan1784
i printed it on the shiny sticker background to make it look a little metallic and got away with it...but then again this is before i knew thsi guy that did smog tests....now when i had the 1jz i used the guy now because i know him and he lets me pass as long as its not too crazy...when i used to have the 7m it was tougher...i was still able to pass since it was a little easier
Broken Rides:
BVSV interchangability?/ Smog josh_crosson MKIII Supra 3 08-16-2008 01:36 AM
Free $$ to fix failed smog test cars - CALI specific mrnickleye Non-Generation Specific Questions 2 06-19-2008 12:20 AM
86.5 7MGE supra smog test fails googoogaga Non-Generation Specific Questions 7 10-18-2006 02:44 AM
Emissions Test Info in "Your" Area/State mrnickleye Off Topic Forum 9 05-01-2006 01:11 AM
Test....... midwestmk2 MKII Supra 0 12-21-2005 08:40 AM
