Old 05-27-2016, 12:14 AM   #1
dilevan
dilevan is on a distinguished road
Default Clutch Master Cylinder Fluid
What fluid is used in the hydraulic clutch system in a 1990 Supra turbo??
dilevan is offline   Reply With Quote
Old 02-19-2018, 06:48 AM   #2
tmothy3
Brake fluid and clutch fluid are the same thing, therefore you can use any DOT3 brake fluid.
How hard is the clutch master cylinder to replace? the#1 MKII Supra 2 05-27-2016 04:32 AM
Clutch master cylinder leaking after 8 months? Awyman18 MKIII Supra 4 05-27-2016 12:26 AM
Need Help with Replacing Clutch Master Cylinder xxx609 MKIII Supra 7 02-01-2012 01:36 AM
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
