Old 11-30-2009, 09:38 AM   #1
suprakillz
suprakillz's Avatar
suprakillz is on a distinguished road
Default can i use 5x112 bolt pattern rim
so the 89 supra has a 5x114 bolt pattern. i found a set of rims that i like, but the bolt pattern is 5x112.. will that fit on my supra?? i'm not sure if that's even a big differnece in size...??
suprakillz is offline   Reply With Quote
Old 12-10-2009, 01:47 AM   #2
suprakillz
suprakillz's Avatar
Default no you cant, not really
so i found out that a different bolt pattern rim other the the one recommended could fit the 89 supra (5x114.3). but once you torque the lug nuts down they could brake the studs off. they can brake off when you are torquing the lug nuts down, or when you are driving. so in other words, just stick with the 5x114 pattern for the 89 supra... so with that said, i am now selling a set of 18" chrome ADR rims with a 5x112 bolt pattern. $450
Old 12-10-2009, 02:00 AM   #3
supranutz
supranutz is on a distinguished road
5x4.5 , 5x115 and 5x114.3 will all work nothing else !!!!
supranutz is offline   Reply With Quote
Old 12-10-2009, 02:38 AM   #4
Actually, anything other than 114.3 can cause problems, even 115. I have known people who have had them machined to work as the difference is minimal, but I'm not going to recommend it.
Old 12-10-2009, 02:42 AM   #5
suprakillz
suprakillz's Avatar
yeah, i almost found that out the hard way. the thing is tho, that you can fit the rim on to the studs, and then you can get tempted to torque them down.
Old 12-10-2009, 02:54 AM   #6
supranutz
only time i have ever had a problem with using 5x114.3 is when the car called for 5x115 or vice versa and i was using an ET style lugnut
if it takes a conical lug it never has been a problem for me
ive done this with over 100 wheels sales in the last 2 years not one comeback
also 5x 4.5 is the exact sae equivelent of 5x115
Old 12-10-2009, 04:12 AM   #7
kamikazemkiii
kamikazemkiii is on a distinguished road
Get what is called for, if u happen to put something make sure that u get the adapter plat that changes the bolt pattern (forgot the name).
kamikazemkiii is offline   Reply With Quote
Old 12-11-2009, 09:02 PM   #8
suprakillz
suprakillz's Avatar
yeah, i think i'll just buy rims with the right bolt pattern, and just keep it on the safe side.
Old 02-09-2010, 03:27 AM   #9
cliffordrican
cliffordrican is on a distinguished road
Default hey
will 350z rims fit i belive there 5x114
cliffordrican is offline   Reply With Quote
Old 02-10-2010, 02:12 AM   #10
There is no such thing as 5x114 that I've ever seen.... it's 5x114.3. And yes, the 350Z is 5x114.3.
Header bolt pattern supraman121 MKIII Supra 1 09-01-2007 05:46 PM
Bolt Pattern cars4me89 MKIII Supra 2 04-28-2007 09:22 PM
What is the bolt pattern for... nickalvrz Non-Generation Specific Questions 6 09-02-2006 05:56 PM
bolt pattern Supra2NR Non-Generation Specific Questions 1 05-07-2006 03:38 PM
bolt pattern sorealsosurreal MKII Supra 1 11-18-2005 04:05 AM
