Old 08-14-2005, 12:33 AM   #1
g hodgson
Guest
Posts: n/a
My Engine Warning Light has Started to come on causing rough running and idle, I am given to understand that this could be caused by the O2 sensor & the ECU being faulty, If this is the case what is their location on the car that I may change them.. 1987 MK11 Turbo Supra.. Thanks and I will Wait For a Reply
Old 08-14-2005, 01:05 AM   #2
ddmcse
ddmcse's Avatar
O2 sensor is bolted right into the elbow behind the turbo
ecu is behind glove box .
it would help if you pull the codes the engine light is recording
heres how
i would check the two (vsv) valves on the intake side uder the intake one is for fuel one is for EGR
both are vacuum switches
you might have a diagram of these 2 switches on the underside of the hood
you might want to check out these service manual pages
EFI troubleshooting
diagnostic
if it's a california car there more O2 sensors
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Knock Sensor Location 1987 N/A ravenmaster MKIII Supra 17 10-25-2006 02:32 AM
knock sensor location marc MKIII Supra 10 09-09-2006 09:26 PM
1jzgte Engine Number Location joolhamdi MKIII Supra 1 05-19-2006 12:04 PM
