Old 07-31-2009, 10:16 PM   #1
gmansupra
gmansupra's Avatar
gmansupra is on a distinguished road
Exclamation jdm 1jzte/ma70 HELP!!!!!!
new here but know the drill LOOK IT UP! have and cannot find any answers. runs and idles fine but will only accel to about 40 mph. has a VERY loud whistle when the power goes away.didnt come w/ map sensor got one off 95 celica gts but not sure abt calabration. have aftermrkt intercooler and downpipe just found i rewired w/ 1jz diag and cant pull codes please any help would be greatly appreciated so i can move back in the house ltttl info 1jzte w/auto and uncut harness w/ecu (mtr#6018383) this is the second motor and is a little dif from first but am using orig wiring hrness
1985 project 1988 w/1jzte/afic/3" stainless exh
gmansupra is offline   Reply With Quote
Old 08-18-2009, 05:43 PM   #2
shiftysupra
shiftysupra's Avatar
1st... have you checked for boost leaks? shaft play on your turbo? you need to tell us. and if you have not please do not say you have just because you dont think it's the problem..
im not sure about the map sensor (not too 1jz savvy) but im quite sure you are using the wrong map sensor... if it's making a loud whisle noise you are most likely running in limp mode because car cant determine fuel/air mix. and 2nd why are you using a 7m harness on a jz engine? dont tell me... your using the 7m n/a ecu as well right? you need to give more info if you want help... none of us are mind readers. report back here and we can go from there.
OH! and one last thing; to be quite honest i dont believe you have used the search button (or google) because when i used it based on your problems (if you actually read, not skim through a couple post and call it a failure) you can find the information you need....
