Old 09-04-2008, 11:44 PM   #1
suprabahamut
Default Transmission Fluid capacity
Just to make sure I have a 88 non turbo with the w58. I changed the fluid in it to day, what came out was less than a liter. What the Haynes manual says is 2.5 quarts is this right amount is this right? I put that much back in there so I hope I did not over fill it thats why I am asking. Other question is I had the car in 3rd on some ramps to help hold it up can the car be in any gear to get all the fluid out? Or does it have to be in neutral? And my last question is I put it through the shifter hole everyone says it is easier so I did, but I broke off one of the bolts holding the shifter in it is bad with just 3 bolts? And is there a torque spec because it was no strength at all to bust off. And can I buy these bolts any where for the one I broke off? What is the size and thread if any one knows?
Old 09-16-2008, 01:28 PM   #2
shiftysupra
shiftysupra's Avatar
shiftysupra is on a distinguished road
yes 2.5 quarts is right for the w58. you should also change the differential as well. uses the same gear oil unless you have an LSD type you can get the addative to add to the gear oil. Yes you can do it throught the shift boot hole. I too had to get new bolt that you can get at home depot. hex bolts are what i got.
shiftysupra is offline   Reply With Quote
Old 09-18-2008, 04:30 AM   #3
suprabahamut
Thanks for the information. I had a feeling, but wanted to check also. Sometimes the haynes manuals are not always right.
Transmission fluid check cgreiner MKIII Supra 1 09-22-2008 02:09 AM
Transmission Fluid Change shiftysupra MKIII Supra 2 09-16-2008 11:21 AM
transmission fluid suprabahamut MKIII Supra 2 08-12-2007 06:04 PM
Draining Transmission Fluid? RNEMESiS42 MKIII Supra 20 05-17-2007 10:17 AM
Transmission Fluid Change phillip_o_hj Non-Generation Specific Questions 7 02-09-2007 08:56 PM
