Old 12-23-2007, 06:58 PM   #1
Busted Knuckles
Busted Knuckles's Avatar
Default Can anyone help me with a stumbling prob?
I got my '88 Supra N/A as a hand-me-down from my dad last year. I've been drooling over this car for 17 years before he just gave it to me. It's been meticulously maintained, and barely shows any of the 235,000 miles the odometer reads.
But, I've got a problem. The computer shows no codes, but when I accelerate a bit hard, it will stumble until it hits 2200 RPM. Then the torque hits like a hammer, and away I go. The car idles fine. But, I can get it to stumble out of gear by just revving it. This happens when the car is fully warmed up. The best way I can describe it is like an old carbuerater that needs overhauling. But I have OEM EFI.
I was chasing a problem when I first got it (wouldn't pass emissions), and have replaced the MAF sensor, CTS, Fuel pressure regulator, and O2 sensor. As I mentioned, the computer is giving me no codes. Anyone have any ideas what to look for?
Thanks.
Old 12-24-2007, 02:56 AM   #2
Pretaco
Does it pass emissions now?
What did it fail on? hydrocarbons, nox, or co?
I am willing to bet the two problems are related.
The other sensor I would test it the tps.
What is your fuel pressure at?
Ray.
Currently Running Good
Old 12-24-2007, 03:07 AM   #3
Busted Knuckles
Yes, it has passed emissions twice now. The original problem was a bad O2 sensor, and the replacement O2 sensor was bad as well. Finally had a mechanic who specializes in Toyota's look at it, and he found that problem.
I don't know what the fuel pressure reads. I have a gauge, but it is for GMs and Ford's with screw-in schreader valves. The guide I have says to make an adapter by drilling a bolt. Does anyone have a better adapter/solution?
Old 12-24-2007, 03:30 AM   #4
Pretaco
There are adapters to fit toyota's but it might be too expensive just to test this out.
Does it feel like one cylinder is missing, or all of them? I would check the plugs, and wires, timing, and test the tps. Otherwise I really don't know.
Old 12-24-2007, 05:33 AM   #5
Busted Knuckles
Yeah, all of them. I'll try that. Thanks.
PLZ!! HELP i have a prob... 5upra lov3r MKIII Supra 14 09-18-2008 10:43 PM
93 Toyota supra prob rossa1234@hotmail.com Non-Generation Specific Questions 3 12-04-2007 04:37 PM
shifting prob supra_91 MKIII Supra 28 02-27-2007 04:44 AM
In Need of Help With Starting Prob 87TurboProject MKIII Supra 2 03-01-2006 08:45 AM
Ah this cars killin me! (engine or turbo prob) sexy91tt MKIII Supra 4 02-15-2006 06:21 AM
