Old 12-05-2007, 01:43 PM   #1
supra91
supra91 is on a distinguished road
Default First Supra 1991
Hi
Just picked up my first Supra 91 MK3. I was wondering what are the main problems if any with the MK3 so I can take care of them first. Car already has suspension work with coilovers, full custom 3inch exhaust, Rotora rotors and EBS brake pads wich all have less than 2000 miles on them.
Thank you Rob.
supra91 is offline   Reply With Quote
Old 12-05-2007, 03:26 PM   #2
Supra2NR
Supra2NR's Avatar
HEADGASKET
if it still has the stock headgasket have it replaced with a metal one
but in order for you to do this you need to have the block machined
also you get that parthenon, small yellow house, birdcage
to the left of the speedo
that is the low coolant level , jus top off the coolant reservoir and you should be fine
any waterfall sound behind the dash, your coolant needs to be burped
the tailight warning light, if it stays on, jus replace the small; box on the tailight
these are what i can think of right now
and welcome to the forums, you will love your car,
and this forum is more of the newbie friendly type
if you got any other questions,
try using the search feature, and most of the answer should be at the faq section
put your car's info in your signature, and itll be easier for pple to help you when you ask a question
Old 12-05-2007, 03:43 PM   #3
j3pz
sounds like someone had already started on the car. main problem with these cars is hg and since its already been started, that may have been taken care of, id check on that if i were you. gl, enjoy the car and forums
Old 12-05-2007, 08:18 PM   #4
supra91
Thank you for the info. I should have the car registered by the end of the week so for now just doing some clean up and replacing some of the hoses with some silicone ones.
1991 Supra - New Shocks going in, what else should I replace while it's apart? unkymurch Non-Generation Specific Questions 1 03-02-2007 01:11 AM
