Old 09-13-2007, 02:28 AM   #1
sentra_tt
sentra_tt is on a distinguished road
Default turbo swap
how much would it cost if i wanted to do the 2jzgtte swap to a N/A supra????!?!??! ...................and what other parts would i need then below?
i know i can get the 2jzgtte for $1900 motor,tranny, manifolds, turbos, mounts, ecu, harness,fuel rail, sensors, injectors, throttle body, CAS, and aternator
sentra_tt is offline   Reply With Quote
Old 09-13-2007, 02:42 AM   #2
supra_91
supra_91's Avatar
you can get all that for only $1900? from where?
Old 09-15-2007, 12:52 PM   #3
If you can get everything you need (from a SUPRA, not an Aristo, for example), and it's all in good working condition, then simply pull the old n/a parts out and put the new TT ones in. Probably about 12 hours of labor for everything...
Old 09-15-2007, 04:59 PM   #4
sentra_tt
you can get all that from www.japandomesticmotor.com
Old 09-16-2007, 04:01 PM   #5
For what it's worth I checked their website. The only 2jz-gte on there is from an Aristo...
Old 09-16-2007, 06:57 PM   #6
supra_91
supra_91's Avatar
and it doesnt come with a tranny
Old 09-23-2007, 06:12 PM   #7
sentra_tt
how do you know its from an aristo? and what is the difference?
Old 09-23-2007, 09:45 PM   #8
The bottom section of the oil pan is in the wrong spot for it to be for a jza80.
Cheap Na to turbo swap supraman121 MKIII Supra 0 12-07-2006 08:03 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
