Old 08-08-2006, 06:58 AM   #1
_dUb_
_dUb_ is on a distinguished road
Default Front Lower Control Arms
Does anyone know where else I could pick up at least one of these other than from Toyota...I'm looking at getting a 95 NA that needs to have the right front one replaced and if I could find a good deal on two might as well have both so hopefully the wear would be equal. Thanks in advance.
_dUb_ is offline   Reply With Quote
Old 08-09-2006, 12:34 PM   #2
For what it's worth, I'd suggest you get a brand-new one from Toyota. That way you get a new ball-joint, with a brand-new rubber grease boot. You also know 100% for sure that it's straight (and won't cause problems with your alignment). You've got a national Toyota distributor right there in Texas that offers a great discount to Supra forum members (Jeff Watson 800-327-2087).
Old 08-09-2006, 03:24 PM   #3
_dUb_
Alright thanks for the advice man. I wasn't sure if there was someplace that offered them aftermarket or anything. If I end up with the car I'll have to give them a call thanks again.
lower control arms eighty2supra MKII Supra 7 02-14-2009 09:08 PM
Timing belt rubbing against lower front cover adamh88 MKIII Supra 4 01-05-2006 11:08 PM
