Old 07-18-2006, 02:06 AM   #1
asnboi512
asnboi512 is on a distinguished road
Exclamation easy question
i have a 97 supra and i would like to know how to reset the maintanace required light thanks
nik
asnboi512 is offline   Reply With Quote
Old 07-18-2006, 12:13 PM   #2
Originally Posted by asnboi512
i have a 97 supra and i would like to know how to reset the maintanace required light...
Just pull the two fuses labeled 'EFI" in your main fuse box (engine bay, near battery). However, note that if your supra really does need maintenance, it's likely the light will come back on again quickly.
Here's a bit more info on troubleshooting the ecu codes that trigger the maintenance required light:
http://www.mkiv.com/techarticles/eng...bd1_codes.html
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
easy question for you supra geniuses tdawg Non-Generation Specific Questions 3 07-16-2008 11:23 AM
Easy Question, Does the MA70 have alot of production line changmeister88 MKIII Supra 1 03-13-2006 10:56 PM
Just got a 1989 Supra! Have an easy Question! V1P3R MKIII Supra 12 03-09-2006 02:26 AM
