Old 06-07-2006, 03:59 AM   #4
Originally Posted by Jap Imports
Squib Malf = ***** Malfunction
I think Squib might be seat belt stalk or pretenioners or something like that !!
Still not found the problem
If you'd like, I know another Mkiv Supra owner in the UK that may be able to help you translate your codes 14 & 22. Please email me privately for his contact information.
Also, has any work been done recently on your Supra? In general, those codes seem to indicate a fault with the ecu itself, and/or wiring to ignition or temp sensors. If any work has been done recently, is it possible that the harness plug was not properly connected to the ecu?
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Hatch Open Warning Light constantly on... TomFraser MKIII Supra 6 06-13-2008 02:07 AM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
