Old 04-17-2013, 05:01 AM   #1
CybergreyMKIV
CybergreyMKIV is on a distinguished road
Default NEED HELP! Want to make non-turbo MKIV faster
Hey guys,
Ive heard a lot of good things about this website and the people on it and I was wondering if I could get some much needed help. I own a 1993 Toyota Supra non-turbo MKIV. Pretty much what I want to do is make it faster add a turbo and anything else that would really make this car into a beast. I was just wondering if someone could help me in the process with what parts are the best for me to use (turbos, etc etc) and put in and maybe what order I should put them in for the best performance. It is a completely stock non-turbo engine so I know have a long way to go but got to start somewhere. Looking forward to hearing from you guys.
Thanks
CybergreyMKIV is offline   Reply With Quote
Old 04-17-2013, 07:21 PM   #2
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Welkom.Wen you say beast how much power do you want and what do you want to use it for every day car,track or drag.
warmkop is offline   Reply With Quote
Old 04-17-2013, 07:32 PM   #3
CybergreyMKIV
It would for just summer driving not something crazy I guess as a race car but I would like it to be enough to be able to beat other cars on the street. Maybe like 500ish hp just enough to wreck anything on the streets.
Old 04-18-2013, 06:05 PM   #4
warmkop
Moderator
warmkop's Avatar
Would you consider swapping the engine with a 2jzgte or do you want to use the 2jzge
Old 04-18-2013, 06:12 PM   #5
CybergreyMKIV
If I absolutely had too I would but I would rather not.
Old 04-19-2013, 07:06 PM   #6
warmkop
Moderator
warmkop's Avatar
-You would need to get a turbo kit for your car, something like this.
http://www.suprastore.com/quprost2jnon.html
-A thicker head gasket like 1.3mm.Need to drop the compression.
-Fuel system upgrades. Pump, injectors, Fuel pressure regulator.Stock fuel system won't supply enough fuel.
-Upgraded clutch kit as the stock clutch won't handle the new power.
-Intercooler kit.
-(Upgraded ignition system)not sure how much the stock ignition can handle.
-Stand alone management system or piggy back system (chip).
Old 04-21-2013, 09:12 PM   #7
-Intercooler kit.
Here's another option. Everything you need is here:
http://www.boostlogic.com/catalog/p1...duct_info.html
Old 03-17-2014, 05:09 AM   #8
SUPRAMARCO
SUPRAMARCO is on a distinguished road
Originally Posted by CybergreyMKIV View Post
Hey guys,
Thanks
Hi. Did you come right with your car?
SUPRAMARCO is offline   Reply With Quote
i have 89 supra na and i want to make to turbo mcallensupra MKIII Supra 7 03-06-2008 08:59 PM
Did they make an original single turbo supra (1994)? ts1994 MKIV Supra 3 07-20-2006 08:18 PM
