Old 04-01-2013, 12:07 PM   #1
supra1993
supra1993 is on a distinguished road
Default Master warning light
Hi guys,
i have 1993 JZA80 supra and the master warning light turns on sometimes and ill have to either disconnect the battery or the EFI fuse.
i have tried doing the DIAGNOSTIC TROUBLE CODE CHECK but no codes were shown.
i have topped the break and engine oil.
but still comes up
any ideas what does that means ?
supra1993 is offline   Reply With Quote
Old 04-06-2013, 04:58 AM   #2
This was in the moderation queue as it was posted in the FAQ section. Moved to the MKIV discussion forum.
Old 04-06-2013, 02:20 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by supra1993 View Post
Hi guys,
but still comes up
Is your Mkiv Supra a TT?
If you don't mind me asking, are you sure you did the diagnostic check correctly? Ime, every time I've seen the red triangle with the exclamation mark, I've been able to read a code..
Codes come up for a large variety of reasons. Anything from a vacuum leak to a bad sensor could be causing it. We really need the code to do the troubleshooting...
Life begins at 30psi.
Brake Warning Light on dash!... *D-Joker* MKIII Supra 6 08-28-2009 12:53 AM
Master Warning Light lamw001 MKIV Supra 7 09-23-2008 01:53 PM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
