Old 01-20-2013, 06:28 PM   #1
ironnate
ironnate is on a distinguished road
Default Previous owner removed antenna
As the title says, previous owner removed the antenna on my 1995 mkiv. I did a search and I couldn't seem to find the best option to replace it. The aftermarket stereo he installed does have an antenna, but I guess he decided it would be better to leave a hole in the body, which has me fearing rust. Any thoughts?
ironnate is offline   Reply With Quote
Old 02-23-2013, 10:35 PM   #2
Apologies for not getting back to you sooner.
I agree the oem antenna should be replaced. I'd recommend another oem power antenna, from Toyota. Your local Toyota dealership should be able to help you out.
If you're looking for something less expensive, you'll probably have to go to an electronics retailer (eg. Best Buy)...their car stereo dept. should be able to:
1) install an affordable aftermarket antenna that fits
...and...more importantly...
2) ensure the oem antenna wire was properly connected to the aftermarket stereo.
Alarm system tampered with by previous owner Dutchvelvet MKIII Supra 2 01-19-2013 09:31 AM
universal antenna? Awyman18 MKIII Supra 1 09-16-2011 09:55 PM
antenna motor question:1991 mk3 rohin02 MKIII Supra 2 04-29-2010 02:35 AM
New supra owner (not running) here What to do next Gengus MKIII Supra 1 11-12-2007 03:46 AM
86 complete radio antenna schneid MKIII Supra 1 08-06-2006 09:59 PM
