Old 01-18-2012, 10:49 PM   #1
priyesh12
priyesh12 is on a distinguished road
Smile Wiring Help for Boost Controller, Fuel Cut, & Turbo Timer (Other forums suck!)
Hey Guys,
I have been on so many forums and none of them have the courtesy to help out a supra owner in need! So I was recommended to this forum and lets see if he was right!
(Warning I am a partial noob but learn fast)
My Issue:
I bought a Gizzmo MS-2, its a full system, includes; boost controller, fuel cut defender and turbo timer.
I have done the connections for the boost controller and fuel cut but am stuck on the last part. The last requirement is to connect wire 'A' to a constant 12v supply and wire 'B' and wire 'C' to ignition one (one needs to be 'on' when the car is on the on position lol) and ignition two. I do not have a noob wiring diagram for my ecu because i would like to connect those wires directly to the ecu....could someone please point out which wires i can tap into to make this work!
I would really appreciate someones help,
Thanks
priyesh12 is offline   Reply With Quote
Old 01-19-2012, 12:23 AM   #2
Codyjamesuno
Originally Posted by priyesh12 View Post
Hey Guys,
My Issue:
Thanks
i'd just pay to have it installed, i know, i am not much help
Old 01-19-2012, 02:05 PM   #3
priyesh12
Thanks,
But I live in a very rural area, there aren't any decent technicians here that I can take it to, I would have to go to south Africa (2 day trip).
Old 01-20-2012, 12:05 AM   #4
Hey Guys,
My Issue:
Thanks
Glad to help, but let's start at the beginning. Are you working on a '93-'98 Toyota Supra? Turbo or non-turbo?
Old 01-20-2012, 03:05 AM   #5
priyesh12
Thanks I really appreciate it,
Okay, I have 1996 twin turbo supra JDM with the manual 6 speed transmission.
I think I can clear up the question even more, from my understanding all I have left to install is the turbo timer part. So I need to find and connect to ignition 1 & 2 with the wires from the device to finish this setup, the question is which wires can I tap into on my ecu to make the magic happen. Or do I have to connect the wires to the stock harness underneath the steering wheel, even there which wires would I have to tap into...hope this helps
Last edited by priyesh12; 01-20-2012 at 03:56 AM. Reason: Added more info cleared up question
Old 01-20-2012, 04:07 AM   #6
Codyjamesuno
Thanks,
yeah, i guess that would be a problem! Im sure the guys can help you on here! They seem to know their !!!!
Old 01-20-2012, 06:57 AM   #7
For a number of reasons I strongly recommend people avoid wiring anything up to the ECU harness on any vehicle unless the installation guide specifically calls for it. In this case, depending on which part of the turbo timer's wiring you're referring to, the current draw may be significantly higher than the harness can handle (resulting in burnt wiring)... This isn't the only concern but it's one of the biggest.
Old 01-20-2012, 02:16 PM   #8
priyesh12
Yeah i guess your right perhaps connecting to ecu might be a risky thing. I have the PDF of the manual for the device below, it's on page 18 (wiring instructions).
So I'm stuck on where to connect the red blue and yellow/green wires.
Perhaps there's a better location to connect those wires...
I appreciate everyone's help
http://gizzmousa.com/file-copies/MS_2_Manual.pdf
Old 01-21-2012, 01:30 PM   #9
If it helps, here are the us-spec tech articles for boost controller, fuel cut controller, and turbo timer installation:
http://www.mkiv.com/techarticles/bcc.../bcc_intro.htm
http://www.mkiv.com/techarticles/fcd/fcd.htm
http://www.mkiv.com/techarticles/avc...all/index.html
http://www.mkiv.com/techarticles/blitz_dsbc/index.html
http://www.mkiv.com/techarticles/hks...urbo_timer.htm
Old 01-21-2012, 08:42 PM   #10
priyesh12
Thanks a million pwpanas! Finally i can get this sorted out!. The turbo timer article helped me out with the issue i had but the rest of the articles are great as well.
Tags
boost controller, diagrams, ecu, turbo timer, wiring
Fs: 2001 Msm Turbo Is300 400+whp richfloresIST Buy/Sell Cars 3 10-05-2011 01:21 AM
turbo timer Guest MKII Supra 5 04-05-2005 06:02 AM
