Old 12-04-2011, 09:10 PM   #11
yoshi123
yoshi123 is on a distinguished road
- where is this located?
- how do I test it?
yoshi123 is offline   Reply With Quote
Old 12-05-2011, 02:21 AM   #12
- how do I test it?
On the US-spec Mkiv TT, the intake air temp sensor is part of the MAF, and is tested by checking the voltage between THA and E2 of the ECM connector...as well as the resistance between pins 3 and 4 on the MAF. All of this is in your TSRM.
Old 12-11-2011, 09:18 AM   #13
yoshi123
Thanks I'll check that too. Haven't done anything with the car, I need to allocate a day for testing and get my friend over.
Old 12-11-2011, 12:09 PM   #14
interested!
Question Car broke down
Hi! have you checked out the earth return at the coil pack to cylinder head , this could be intermittent if stiffened and corroded , always a good idea to boost wiring gauge ( double-up ) and lengthen to improve flexibility = make a new one ! and see if that makes any difference - worked for me, mine was just about to fall apart!- talking about my mk 3 -7mgte here!
Old 02-04-2012, 03:56 PM   #15
yoshi123
OK, at long last I get round to taking the engine cover off.
As we did a spark test, we noted a connector at the back came out really easy.
Hmmm...
Then we notice 3 clips are broken and silicone sealant is used to hold them together. The clip that came out really easy, the silicone was completely broken.
http://imageshack.us/f/19/aristo.jpg/
We then plugged the lose connector in and ran the car for 40mins in idle, it did not cut out (typical 10-15 mins then cut out before). So I think this is probably the cause of the problem. I need to do more testing, but it looks promising.
My guess is the clips broke during a spark plug change and my mechanic sealed them.
My questions :
- what is the part number for these clips?
- I see 3 with silicone sealant, are there any more clips than the 3?
Old 02-04-2012, 04:41 PM   #16
Hmmm...
My questions :
http://www.mkiv.com/techarticles/par...ess/index.html
Old 02-04-2012, 08:53 PM   #17
yoshi123
awesome!
How many do I need???
Old 02-05-2012, 12:14 AM   #18
awesome!
Um...how many broken coil connector clips do you have???
Old 02-06-2012, 07:54 PM   #19
yoshi123
I can see 3 broken clips, just wondered if there were any more underneath all the cables?
Old 02-08-2012, 07:35 PM   #20
Nope...on the Mkiv Supra Turbo's non-VVTi 2jz-gte (US-spec), the coils plug directly onto the spark plugs. There are six clips in total from the harness to the coils - I'd recommend you replace all six of them, since all six are likely damaged due to heat (some a bit more than others of course, but I doubt even one is like-new).
If it ain't broke don't fix it vbryanv MKIII Supra 3 04-04-2011 05:39 PM
oops i broke the headlight help supraluver4life MKIII Supra 13 12-22-2009 04:04 AM
Speedo cable broke. What next? Busted Knuckles MKIII Supra 5 10-25-2009 06:01 AM
Broke something.. and i dont know what it is. help. Kevin MKIII Supra 2 06-08-2009 12:10 PM
my 86 broke pittsupra MKII Supra 2 06-05-2006 11:42 AM
