Old 04-25-2011, 07:36 AM   #1
Alfa_Zulu
Alfa_Zulu is on a distinguished road
Default Engine locks at high rpm
When I run the engine close to the rev limiter the engine just locks briefly.
Thought it could be something to do with the valves not opening far enough to let the exhaust gasses out.
I'd appreciate any suggestions, and if you need more info just let me know
Alfa_Zulu is offline   Reply With Quote
Old 04-25-2011, 06:31 PM   #2
You're going to have to explain precisely what "locks" means to you. To me it's a seized engine and those aren't a temporary issue.
Old 04-26-2011, 11:37 AM   #3
Alfa_Zulu
Well it seems as though the exhaust gasses can't escape fast enough so some of it stays in the cylinder through the next intake and compression stroke causing to lock, a friend called it compression lock but I'm not real sure haha
Old 04-28-2011, 02:08 AM   #4
mike91
mike91 is on a distinguished road
your probably just hitting the fuel cut.
91 supra turbo targa
mike91 is offline   Reply With Quote
Old 04-28-2011, 05:49 AM   #5
Alfa_Zulu
No, this actually completely locks the drivetrain and the wheels for a brief second, if it was fuel flow it should just rev down shouldn't it?
Old 04-28-2011, 11:50 PM   #6
mike91
I'm pretty sure it could be. Kuz when I was doing some mods on my cars and hit fuel cut it felt like I hit a wall real quick and then kept going. And ya it happened when at high RPM. What mods have you done to your car?
Old 04-29-2011, 12:12 AM   #7
mike91
? do your wheels lock up and slide? or does it just feel like that?ha if they are stop driving it! LOL take your car into a shop, not a regular shop but a shop that knows performance cars. its guna be more $ but its worth it in the long run.
Old 04-29-2011, 08:53 AM   #8
Alfa_Zulu
I think it just feels like it, not real sure lol. There aren't any mods atm so it could be fuel flow then
Old 04-30-2011, 02:44 AM   #9
pwpanas
Supra Owner
pwpanas's Avatar
No mods at all? Not even to raise the boost? With a 100% bone-stock Mkiv Supra Turbo, you should never hit fuel cut...unless perhaps your wastegate VSV or your wastegate actuator is malfunctioning.
I agree with the others - if you are running more than oem boost levels, fuel cut does feel like you just ran into a wall.
Life begins at 30psi.
Check engine light at high RPM's BlueTuner MKIII Supra 4 12-26-2009 08:37 PM
high speed(rpm) engine cuts out??? help!!! krahs912 MKIV Supra 3 08-14-2009 11:21 AM
turbo kit on high mileage engine supra_racer05 MKIV Supra 1 11-30-2007 11:37 AM
