Old 01-18-2011, 07:28 PM   #1
TZimmz
TZimmz is on a distinguished road
Default fuel injecots
i have RHD 94 Supra and im looking to upgrade my fuel injecetors.
what kind of fuel injectors would someone use without replacing the fuel rail.
TZimmz is offline   Reply With Quote
Old 01-19-2011, 02:05 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
SaRD 800s or 850s...
https://www.speedforsale.com/suprapa...ail-p-648.html
Note - with this one change only, your injectors will outflow your oem fuel pump and your oem fuel lines. In other words, this one change alone won't allow you to deliver 800rwhp worth of fuel to your engine.
Life begins at 30psi.
Old 01-19-2011, 08:23 PM   #3
Fuel Injector Clinic
Fuel Injector Clinic's Avatar
Fuel Injector Clinic is on a distinguished road
What is holding you back from buying the rail?
Chuck,
Fuel Injector Clinic is offline   Reply With Quote
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
