Old 11-16-2010, 12:09 AM   #1
jheddings22
jheddings22 is on a distinguished road
Default Car wont start
My 95 Supra clicks about 3 ro 4 times before finally cranking over and starting. Any suggestions before i change the ignition and starter. The alternator and battery are both good also.
Thanks
jheddings22 is offline   Reply With Quote
Old 11-16-2010, 05:01 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Please post new threads in the appropriate forum. This thread is moved to the MKIV section.
It sounds like you may have a bad connection on the battery cable running to the starter. Ensure that there is NO corrosion, that the terminals are tight (at the battery and the starter), and that the battery cable itself does not have any abnormally hard or soft spots in it.
Old 11-16-2010, 07:31 PM   #3
jheddings22
i have replaced the terminals and traced to the starter and have no corrosion and good connection. The funny thing is when i get the car started and run for a good 20 minutes, it will crank right up later. Its when the car has not been started for a long period of time that it has that problem.
Old 11-17-2010, 11:43 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
It's possibly a bad starter... Of the many dozens and dozens of Mkiv's I've worked on, I haven't heard of this problem before.
Note: A starter rebuild kit from 'yota is very affordable...
Life begins at 30psi.
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
87 non turbo wont start, need some advice...please. HotRodV6 MKIII Supra 3 09-02-2010 07:29 AM
Stalling at start up Green7mgte MKIII Supra 4 12-15-2009 06:31 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
