Old 11-04-2010, 06:08 PM   #1
JDM Supgra
JDM Supgra is on a distinguished road
Default How on earth do you retrieve diagnotics codes on 1994 JDM Surpa?
Hi All,
I got a 94 supra Twinturbo and would like to know how to retreive diagnostic codes from the ECU, I don't see an engine light indicator, however, there is some Triangle looking shape light. I tried jumping TE1 and E1 (if I remember correctly), but did not see any light flashing. I believe the code retrieval on JDM suppra might be different, if any one knows how, please share it with me and if you have a description of the fault codes, please share it with me.
Thank you for your time.
Rafi
JDM Supgra is offline   Reply With Quote
Old 11-07-2010, 04:58 PM   #2
Originally Posted by JDM Supgra View Post
Hi All,
Rafi
Hi Rafi,
This may help:
http://mkiv.supras.org.nz/
Old 11-07-2010, 05:34 PM   #3
JDM Supgra
Default figured out the issue
I found where the engine light is located and noticed it does not turn on nor the oil light comes one when you open the ignition, I took that part of the circuit apart and noticed the solder on the connect pins were cracked, so resoldered them and was able to read the codes and I was getting code 42 which is vehicle speed sensor, so I guess I need to replace it.
Cheers,
Rafi
Old 11-08-2010, 10:47 AM   #4
Cheers,
Rafi
Thank you for posting back here and keeping us updated. Excellent work on your troubleshooting of why you weren't getting any diagnostic codes.
Regarding your speed sensor, note that the signal actually goes through the odometer. It's possible the odometer panel circuit solder joints need to be re-flowed as well.
