Old 10-06-2010, 07:05 PM   #1
92FoxBody
92FoxBody is on a distinguished road
Ok guys..As you may know I own a mustang (my screename says it..) and I have a few questions about a 1993 supra. This kid I know has a 1993 stickshift N/A supra. It's got gay exhaust,wing,carbon fiber hood etc. It's riced out now but he says he plans on doing a turbo by February. What block is this? Is it the 2JZ? That's what he's telling me. He's going to do a single turbo,stock heads,stock cams and exhaust with 20psi running through it. How likely is this? Thanks guys
He also said he's going to be pushing 600HP. I don't know if he means at the tire or flywheel but either one seems farfetched to me.
92FoxBody is offline   Reply With Quote
Old 10-07-2010, 01:11 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
Yes if he has a 93 which is the newer style body then it is a 2jzge If he were really goin to push .20psi. Then he would be around the 600hp range. But I wouldn't suggest more then 18psi. Due to the limits of the valvetrain is 600 the blocks stock can handle 900hp believe it or not. its true he would have to upgrade fuel system and fuel management or better yet a standalone EMS. But if he has the pockets for it. I wouldn't race him. Or he will hand your ass to you in your stang.
Valvetrain good for 600hp to the crank..not far fetched at all very possible, all day long. And still reliable..
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 10-08-2010, 02:48 AM   #3
92FoxBody
Seemed farfetched to me because It was an N/A car. I thought it was a different block than the 2jz...Maybe I won't race him after all However...I will be spraying my car next summer. I think I can get him with that Won't his tranny blow at that rate too though? It's a 5 speed.
Old 10-08-2010, 02:57 AM   #4
Travis89Turbo
Blocks are the same there are 2jzge which is na. And a 2jzgte. Same blocks and heads just different bolt ons for the most part slight differences in them. And yes the tranny would need to he upgraded to the turbo trans, the r 154 which is a bullet proof tranny. People run upwards of 1200hp on them with just one upgraded part in the trans.. the tranny he has is only good till about 450hp..
Sorry but even on spray if he has the money to properly build it. He will still handle your 5.0 don't mess with supras they have a kick that most street muscle cars don't have.. not to mention his engine will last 5 times longer then yours on spray.. u would need deep pockets to keep up
stock 2jzge
Old 10-08-2010, 10:38 AM   #5
Actually not quite. The 2jz-gte has oil squirters, which keep the pistons cooler under boost. Of course, the 2jz-ge also has higher compression pistons (which is worse for forced induction).
The 2jz-gte head is TOTALLY different from the 2jz-ge head (major differences).
Old 10-08-2010, 11:12 AM   #6
Travis89Turbo
Okay. I apologize thank you for correcting me!
stock 2jzge
Old 10-08-2010, 05:44 PM   #7
92FoxBody
So if I add a 150 shot to my car and run high 10's he'll keep up?? I wouldn't think so...Besides, This kid can't drive And nitrous does not affect the longevity of your motor. It all depends on the tune But thanks for the info guys. Both of you I was looking at supras at first...Then realized a TT would run over 20K...So I grabbed my car for 2,100$
Old 10-09-2010, 01:47 PM   #8
No need to apologize! I'm glad I could help to clarify...
Old 10-09-2010, 01:48 PM   #9
Out of the hole, you have the advantage...especially dollar-for-dollar. However, from a rolling start on the highway a turbo'd mkiv will be very competitive. Also, through the twisties it's likely even an n/a will have the advantage.
Old 10-09-2010, 02:13 PM   #10
Travis89Turbo
Come on man.150 shot on a stock motor and your sayin it won't affect the longevity of your motor? That's like running 25 psi on a stock motor... and even with that u won't hit high tens. But please do it and let us know how it works for ya.. remember your engine wasn't designed to be boosted or sprayed.
stock 2jzge
88 Supra.. body work and engine question - quickies : ) Grandavi MKIII Supra 5 10-08-2010 04:58 AM
Engine harness question between auto and manual gambit1982 MKIV Supra 4 05-25-2010 05:34 AM
1983 supra engine question 101jinx101 MKII Supra 0 12-06-2007 10:47 AM
new engine question D_Train MKIII Supra 7 04-29-2007 08:47 PM
