Old 08-04-2010, 02:37 AM   #1
TZimmz
TZimmz is on a distinguished road
Default 94 JMD Supra idle problem.
Hey I bought a 94 JMD Supra and its doesnt idle just right.
i heard rumours about maybe it has to be tuned because the
tuning in japan doesnt run just right in North America.
Can anyone give me any direction?
TZimmz is offline   Reply With Quote
Old 08-05-2010, 01:23 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
TT or N/A? 6spd or auto? Could you post a pic of the engine bay?
Life begins at 30psi.
Old 08-05-2010, 03:23 AM   #3
TZimmz
definatly a 6 spd and definatly twin turbo
it stock with a blitz short ram
and a intercooler piping kit
Old 08-05-2010, 09:04 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
My first suspect would be a vacuum leak ... anywhere within your charge-air system. Most likely you should start with the intercooler piping kit - for example, sometimes a t-bolt clamp can squeeze a pipe so hard as to dent it, which can in turn cause a vacuum leak. Do you have the tools necessary to pressurize your charge-air system?
Old 08-12-2010, 08:46 AM   #5
Sapar
Sapar is on a distinguished road
Default Mine too
Mine used to idle funny as well, turns out I had a leaky valve.
Could do a compression test, or unplug the fuel pump and wait for it to stop and crank it. Should have an even turn over, a quicker turn every now and again means bad compression in one cylinder.
Hopefully its not that!
Sapar is offline   Reply With Quote
Old 08-27-2010, 01:00 PM   #6
Durandal
Durandal's Avatar
Durandal is on a distinguished road
I take it you have an aftermarket ECU where you mention tuning in Japan?
Durandal is offline   Reply With Quote
Old 10-22-2010, 06:32 AM   #7
kylej
kylej is on a distinguished road
I'm gonna go with buddy and say its a vacuum leak, and there more a pain in the ass finding, atleast on vw's I haven't worked on a supra yet mines still in the mail, it'll be like christmas when I get that baby.
kylej is offline   Reply With Quote
Old 10-23-2010, 01:30 PM   #8
pwpanas
Supra Owner
pwpanas's Avatar
Finding a vacuum leak is easy - just pressurize the charge-air system.
87 Turbo Supra rough engine problem SupraKat MKIII Supra 8 06-26-2010 05:33 AM
Got My Supra! ... and a problem. :) jeffpritchard MKIII Supra 12 05-07-2010 01:16 AM
1990 supra turbo problem. Rob1 MKIII Supra 5 04-12-2010 01:34 PM
Idle problem again. redmaro MKIII Supra 17 02-10-2007 07:42 AM
Idle Position Sensor Problem White87Turbo MKIII Supra 4 06-20-2006 05:38 AM
