Old 01-26-2010, 06:15 PM   #1
ravi4001
ravi4001 is on a distinguished road
Default WTK Part numbers from engine number
hey guys-did a full conversion(engine,diff,tranny) on my supra from non turbo- turbo
because of this sometimes i need parts for the engine and transmission, however because i have no vin number i find it very difficult(most sites require a vin).
Is there any website i can use to obtain a vin number or part numbers using my engine number
ravi4001 is offline   Reply With Quote
Old 01-26-2010, 06:25 PM   #2
You can search by category and description here: http://www.toyodiy.com/parts/ You may either enter a VIN or you may drill down by selecting model/year/equipment. Unfortunately, they were forced by Toyota to remove their picture catalog...
Another place you can search (with pictures) is www.toyotaworld.com (Champion Toyota of Texas). Their site won't provide part numbers though, but it has pictures... click on 'Buy parts online' to enter their online shop.
Hopefully someone has some more options for you as well, those are all I know of for the MKIV.
Old 01-26-2010, 06:28 PM   #3
ravi4001
the problem is i dont know the year of the engine.
iknow it came out of a toyota aristo... but thats all i got and the engine number
Old 01-26-2010, 07:18 PM   #4
Well, I don't know a lot about what all was changed from one revision to the next.... hopefully someone will chime in with more. Is the engine VVT-I equipped? Post the numbers you do have (engine, ECU part number...)
Old 01-27-2010, 10:12 PM   #5
If it helps, VVTi was not introduced in the Mkiv Supra till '99 (Japanese-spec). I'd guess if the Aristo engine is VVTi, it's '98+...
Old 01-28-2010, 12:34 AM   #6
I figured it would help date it. I didn't know the specific dates, bt i knew it was a later addition. Thanks for the info!
1984 Engine Swaps and part fittings Lil Jup MKII Supra 1 11-14-2009 09:27 PM
VAF check engine light on code number #2 1989 8secmkiii owner MKIII Supra 6 01-26-2009 08:54 AM
fuel pump hanger part numbers rlipp69 Non-Generation Specific Questions 0 06-18-2007 03:23 AM
1jzgte Engine Number Location joolhamdi MKIII Supra 1 05-19-2006 12:04 PM
