Old 11-22-2008, 01:05 AM   #1
DBHONDA2
DBHONDA2 is on a distinguished road
Default Please Help Need Ecu Mkiv N/a Auto
i could really use some help i am trying to fix my brothers car while he is at boot camp for the marines he has a 95 toyota supra n/a automatic and is is not running and the ecu is bad and unrebuildable and i have been unable to find one to replace it so we can get it fixed before he comes home. what really sucks is that he bought the 10 days before he left for boot camp and only got to drive it twice before it messed up so please help if you can. give me a call
daniel 9042262958
DBHONDA2 is offline   Reply With Quote
Old 11-22-2008, 11:06 AM   #2
daniel 9042262958
If you're 100% sure that the ecu is bad, the only choice is replacement. You might be able to find one on ebay...just be sure it's for an n/a auto, and the correct year. Worst case, you may need to purchase a replacement ecu from Toyota.
Old 11-22-2008, 03:20 PM   #3
DBHONDA2
i am 100% sure the ecu is bad. there is no check engine light coming on when you turn the key on which means the ecu is bad.
the problem i am having is i connot find an ecu and i allready had this one rebuilt and it is still not fixed.
toyota says there are none available in us or japan.
i have only been able to find five speed ones so far
Old 11-23-2008, 03:51 PM   #4
i am 100% sure the ecu is bad. there is no check engine light coming on when you turn the key on which means the ecu is bad...
Could also mean a bad connection between the ecu and the harness, for example...
...the problem i am having is i connot find an ecu and i allready had this one rebuilt and it is still not fixed.
Just be patient...parts for the mkiv are posted on ebay occasionally. This is a rare car though, so the total volume of parts is somwhat limited (i.e. specific used parts are only available infrequently).
You could try posting WTB posts on this forum, and others.
Parts Wanted - Toyota Supra Forums
Also try Jeff Watson 800-327-2087 (Champion Toyota).
can i learn to drift using mkiv auto? seantanct Non-Generation Specific Questions 5 01-08-2009 09:58 PM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
