Old 08-05-2008, 11:10 PM   #1
whitetiger777
whitetiger777's Avatar
whitetiger777 is on a distinguished road
Default Need Help on Insallation of Sparco Wheel (No Horn)
I've installed the sparco hub and wheel on my MKIV TT 6_Spd. The problem is I can't figure out how to hook up the horn. Apparently it has something to do with the clock spring. Unfortunately the sparco hub will not fit on the wheel shaft while the clock spring is in place due to a plug and wire (See Pics). Any help would be appreciated.
The Spraco hub lines up with the outside circumference of the yellow sticker.
The plug and wire that don't allow the hub to seat. (would have to be broken or cut off)
whitetiger777 is offline   Reply With Quote
Old 08-06-2008, 03:09 AM   #2
I'm not sure, but I think that hub has something to do with the airbag. If you remove it, that should probably be the only downside? When I swapped my '94 oem mkiv tt 'brick' airbag steering wheel for an MR2 w/airbag, the only thing I had to add is an airbag plug adapter...oh, and I lost my cruise control lever.
Old 08-06-2008, 06:44 AM   #3
whitetiger777
Ya, I've got a sparco wheel, no airbag, no cruise controll, no problem, but no horn in LA big problem....
Old 08-06-2008, 11:15 PM   #4
Possibly, you could trace the problem with the TSRM Electrical:
MKIV.COM
Old 08-07-2008, 02:49 AM   #5
whitetiger777
TSRM electrical????
Old 08-07-2008, 09:05 PM   #6
TSRM electrical????
Did you follow the link in my post?
replacing wheel stud Rahnter MKIV Supra 3 12-10-2008 03:57 PM
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
Aftermarket steering wheel RTZ MKIII Supra 10 02-07-2008 08:44 AM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
What do i need for my steering wheel. paula Non-Generation Specific Questions 1 07-17-2006 01:03 PM
