Old 04-09-2008, 11:29 PM   #1
Bone_Stock_Supra
Bone_Stock_Supra is on a distinguished road
Default Need help with differential mounts!!
As everybody knows, the diff. is held in place with two front bushings and two rear bushings that actually go through the sub-frame. I recently blew the passenger rear bushing out so I have been driving around with the front two and the driver rear holding in the differential. I recently purchased the replacement bushing and the allen-head bolt that holds it in and took it to my local mechanic. He removed the exhaust and even dropped down the swaybar but could not get the bushing pressed into the subframe. Has anybody had this problem? How do you get the bushings into the subframe? Any DIY guides would be very helpful. Thanks!
2008 VW Touareg
1993 NA MK IV Supra
Bone_Stock_Supra is offline   Reply With Quote
Old 04-11-2008, 03:54 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Have you checked the appropriate section of the TSRM? I'm not sure if it covers rear diff/subframe bushings, but I'd say that's the most likely place you'll find that information. I'd suggest starting in the section that describes removal & reinstallation of the differential.
Life begins at 30psi.
differential swap or not kkiepvvessau MKIV Supra 22 09-02-2008 01:55 AM
MKIII Differential SupraSleuth Non-Generation Specific Questions 3 08-06-2008 02:44 AM
limite slip differential suprabahamut MKIII Supra 0 08-22-2007 04:08 AM
Differential gearing changes? jibbby MKIV Supra 0 02-23-2006 07:51 PM
Motor Mounts chrisr3344 MKIII Supra 1 01-30-2006 02:54 AM
