Old 11-30-2007, 10:18 AM   #1
supra_racer05
supra_racer05 is on a distinguished road
Default turbo kit on high mileage engine
I just recently baught a '94 supra that has the N/A engine, and I'm planning on going with the boost logics stage 2 turbo kit and running it with a Greddy Emange Ultimate. I'm just curious if it's safe to install a turbo kit on it now since it has 110K miles on it? The head gasket will be changed and head studs put in as well.
supra_racer05 is offline   Reply With Quote
Old 11-30-2007, 11:37 AM   #2
Originally Posted by supra_racer05 View Post
I just recently baught a '94 supra that has the N/A engine, and I'm planning on going with the boost logic's stage 2 turbo kit and running it with a Greddy Emange Ultimate. I'm just curious if it's safe to install a turbo kit on it now since it has 110K miles on it? The head gasket will be changed and head studs put in as well.
You need to do compression & leakdown tests on your engine to determine its condition.
i want to drop in a turbo engine in to a non turbo cody_18_06 Non-Generation Specific Questions 1 11-02-2005 03:10 AM
