Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIV Supra > MKIV FAQ
Old 09-28-2011, 09:01 PM   #1
norcalkev
Banned
norcalkev is on a distinguished road
Default V160/161 comparison
hey all i have some questions pertaining to this V161 tranny used in the supra. Was this a JDM tranny or was it used in U.S. production models as well? also I noticed it has closer gear ratios than the V160... Did this make it faster in the 1/4 mile? I assume it's the same build as the V160 with different gear ratios? thx
norcalkev is offline   Reply With Quote
Old 10-01-2011, 04:07 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
http://www.mkiv.com/techarticles/getrag_ratio/getrag_233_ratio_info.xls
http://www.mkiv.com/techarticles/getrag/v161/v161_3.jpg
Gears - V160 (3.827,2.360,1.685,1.312,1.000,0.793, Rev 3.280) - May 1993 to May 1996
Gears - V161 (3.724,2.246,1.541,1.205,1.000,0.818, Rev 3.192) - June 1996 to July 2002
From Wikipedia:
http://en.wikipedia.org/wiki/Toyota_Supra
http://en.wikipedia.org/wiki/Toyota_JZ_engine
http://en.wikipedia.org/wiki/Toyota_V_transmission
Getrag
Gearbox
6 Speed (V160) / (V161)
First.........3.827 / 3.724
Second....2.360 / 2.246
Third.......1.685 / 1.541
Fourth.....1.312 / 1.205
Fifth.........1.000 / 1.000
Sixth........0.793 / 0.818
Reverse...3.280 / 3.192
Final Drive 3.266 (all TT), 3.769 (NA)
Oil (L) 1.8
...and finally, from: http://www.turbosupras.com/pages/pages/specifications/JZA80/jza80.htm
Life begins at 30psi.
Oil Pan Gasket Comparison..... kaine614 MKIII Supra 6 04-03-2010 07:15 PM
