Old 10-20-2007, 05:37 PM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Exclamation Help...Turbo Problems
so i searched around the site but i couldn't find any posts that ansured my Q. so
here is my problem i rebuilt my top end and fixed a Blown head gasket.
i used arp studs and cometic MLS HG, i have oversized valves and some bolt- ons. When i put it all together i was hitting what felt like fuel cut,but was not, at 3,000 rpm so i tightend some vacuum hoed the boost leaks. I think i blew out my turbo? but why, it was at stock psi (i did install a MBC) please help.
-the turbo was leaking from the feed line so i bought a new gasket and fixed it, now when i pull off the intake i notice a little oil..
please help i need it to run soon..
Thanks in advance,
Nick
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Old 10-29-2007, 12:14 AM   #2
Supra_87_mk3
Angry
well thankyou for your help , i pulled the turbo and the shaft is bent turbo's junk.
Old 10-31-2007, 01:23 AM   #3
jfunez
jfunez's Avatar
how did it happen?
post pictures dude...
Old 11-10-2007, 07:51 AM   #4
Supra_87_mk3
every turbo has a speed that it can spin w/o damaging it's self and if it free spins faster than that speed the shaft will flex cousing it to hit the wall of the turbo.... thus a bent shaft...i think when i was hitting what felt like fuel cut. it must have free spun...
my 89 turbo auto problems twerb089 MKIII Supra 6 03-11-2008 06:26 PM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
