Old 10-18-2007, 02:31 PM   #1
Kuban
Default ring wear on walls
i have a jasper remanufactured block, its got 5k miles on it. the hg blew a while ago and its been sitting ever since. i pulled the head and saw ring wear on the walls. no actual groves, but wear marks. i work in a high precision machine shop, all the big engine builders here are telling me to hone the bore and just get new rings.anyone else disagree? also if anyones interested, im going to be machining my own billet forged 6061 t651 aluminum pistons. modeled after JE. balpark 400$ area.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Old 10-18-2007, 06:23 PM   #2
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
i would hone the cylinders just to be safe.
and can you make those pistons in a 10:1 comression? if so i might be interested
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 10-18-2007, 06:44 PM   #3
Kuban
i probably could. but i would need another piston, to measure, to get the dimensions.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Clutch wear question suprabahamut Non-Generation Specific Questions 2 09-14-2008 04:20 PM
changing out ring gear Burn N' Up MKIII Supra 0 08-30-2006 07:09 PM
