Old 10-14-2007, 05:13 AM   #1
Gunnar
Gunnar's Avatar
Gunnar is on a distinguished road
Default Shim and boost questions + afr
My supra is being delivered on monday, i got one with a metal head gasket and arp bolts installed, needs a new paintjob but the mechanical side of the thing is realy good.
Now, i got me the 550cc injectors, lexus afm, afr meter and extra boostgauge.
With the standard turbo and those mods how many shims or what boost should i go for?
Then the afr meter i got doesn't have a probe, it just says in the manual that the green wire goes to the o2 sensor. If i hook this up with a split cable to the wire that goes from the ecu to the o2 sensor won't i screw up my signal due to parallel resistance values?
Gunnar is offline   Reply With Quote
Old 10-14-2007, 06:51 AM   #2
86_sports_1jz
86_sports_1jz's Avatar
86_sports_1jz is on a distinguished road
14 psi max, just stick two walshers between the compressor housing and actuator
GOVERMENT APPROVED HIGH SPEED VEHICLE
86_sports_1jz is offline   Reply With Quote
Old 10-14-2007, 06:17 PM   #3
redmaro
The max boost on the stock Ct26 turbo is about 14psi, but teh turbo probably wont last much at those boost levels. So i would go a little lower If i were you. And also placing 2 shims wont get you 14 psi, youd need longer bolts to get that high.
MK3, Auto, Turbo.
Boost issue.. Kinda... 2JZEFINI-17 MKIII Supra 1 11-12-2006 02:54 PM
Shim josecampos47 Non-Generation Specific Questions 0 01-17-2006 02:04 PM
