Old 10-14-2007, 02:54 AM   #1
mkiiisupra
Exclamation ~~~Boost problem please help
Problem was turbo gauge shows boost but none of the power gets to the engine
took to several mechanics all said to replace the turbo... soo had a turbo rebuilt and updgraded it to a 60-1 trim or w/e
Put the new turbo in my car also replaced alot of rubber hoses that where cracked or had lost all flexibility.
Same problem, guage shows boost but no extra power gets to engine. at my wits end please help....
Side note, there is slight increased power. very minimal i think its due to the upgrade on this turbo when compared to the last, but somewhere along the way i loose most of my boost.
Old 10-14-2007, 03:36 AM   #2
kwnate
SP58GT
if the gauge is reading 8lbs then the motor is getting 8lbs as the sensor reads off the intake manifold. Are you getting any codes? Possibly code 52? Also check your timing.
Nate
Old 10-14-2007, 03:47 AM   #3
mkiiisupra
ok, how does timing affect the amount of power my car gives me, when the boost cut on before it used to put me back in my seat i could FEEL the diffrence when it cut on....
something happend stoped feeling it, it was off and on for awhile then stoped giving me power all together. Places told me my wastegate was stuck open...
after pulling the turbo off the car realized that was not the problem... a little late at that point....
How do i check my timing? thanks for your help wish you where there when i posted about it in first place maybe woulda saved me the 750 for rebuiling a old turbo a had laying around with upgraded trim... ah well least i know my turbo will support my goal of 400-450hp and is in top shape
Old 10-14-2007, 03:48 AM   #4
mkiiisupra
if you want and you have it, contact me on msn kaelthas_lineage2@hotmail.com
i apreciate the help.
Old 10-14-2007, 03:50 AM   #5
mkiiisupra
my engine light is not on
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
