Old 10-12-2007, 03:38 PM   #1
supraman121
Default Removing the struts
When i bought my kyb front struts i was going to install them then i got under the car and looked at it and it looks like a big puzzel so i gave up and took it to a shop, so i was wondering if anyone could give me some pictures of what i have to unbolt to get the strut and spring out.
How far can the car be lowered using the stock struts i was told 2" front and back, anything lower the 2" i was told i would have to get some different struts?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 10-13-2007, 02:17 AM   #2
Supra2NR
Supra2NR's Avatar
mine dropped more than 2"
probly around 2.5" both front and rear
but my rear right now is even lower, as the shocks are blown
so the wheel is almost tucked under the wheelwell
the front is a little bit tricky to take out,
i had to take out the control arms to get the shocks in
the rear is a lot easier to replace
Old 10-13-2007, 02:58 AM   #3
supraman121
This is on your stock struts? What type of struts do you have? And were did you find 2.5" lowering springs i cant even find 2" anymore?
K&N Air Filter
Old 10-13-2007, 11:45 AM   #4
IHateHacks
IHateHacks's Avatar
Replacing struts on a MK3 is far from a puzzle, its actually one of the easiest vehicles to lower, if you don't believe me go try lowering an 80's chevy.
All you need is a 19mm socket, 19mm wrench and a big fuckin breaker bar at least 2 feet long. In the front you need to unbolt the upper control arm by taking that long ass bolt out. Have fun extracting it, as the whole wheel well is built around that bolt. The rears are very simple, just unbolt the strut and wrestle with it for a while, should not take you more than 1 hour for the rears and maybe 3 hours for the fronts.
Old 10-13-2007, 04:30 PM   #5
supraman121
i replaced the shocks on my dads tacoma and that was much easyer to replace then the struts on my car.
K&N Air Filter
Old 10-14-2007, 06:39 AM   #6
supraman121
I cant find 2" lowering springs for the supra (1986 non turbo) any where does anyone know were i could find a full set?
K&N Air Filter
Old 10-15-2007, 02:49 AM   #7
Supra2NR
Supra2NR's Avatar
its not on the stock shocks,
i got kyb shocks, and idk about the srpings
i got it from a friend of mine paid 100 bucks for all four
imma go try to figure that out when i get the chance
probly tuesday the earliest
oh it wasnt a puzzle jus a bit of a b***h if you dont have the right tools
2hr 45min took me for the front , and 47mins for the rear, i timed myself when i was doing mine
Old 10-15-2007, 02:53 AM   #8
supraman121
When i said stock i didnt mean the ones that came on the car from the factory just stock replacement struts, i have kybs on the front but as far as i know they can only be lowered so far.
K&N Air Filter
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
removing a 7mgte from MK3 tokis MKIII Supra 2 11-17-2007 03:34 AM
help picking out new struts mad_dicer MKIII Supra 19 10-11-2006 01:09 AM
Removing the SAFC-2 MDellboy420 MKIII Supra 0 01-27-2006 03:02 PM
