Old 10-11-2007, 04:13 AM   #1
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
Default help my idle speed
please help me my idle on my 1987 toyota supra turbo 5 spd is to high it currently sits at 1000-1100 when its warm and cold where is the screw to adjust it if there is ir how do i adjust it? thnx
cyanide-is-a-way-out is offline   Reply With Quote
Old 10-11-2007, 04:36 AM   #2
redmaro
Check your check engine codes, and dont mess with the idle screw unless youve moved it.
MK3, Auto, Turbo.
Old 10-11-2007, 04:59 AM   #3
well i just found the idle screw like 20 mins ago and adjusted it but i didnt get this till after whats so bad if i adjusted it?? and also it idles and 650 now but the air fuel is wack cause where this one screw was sposed to go it get loose all the time and moves down on this rubber valve thing on the left side of the throttle boddy witch is like hooked into a fuel filter thing its like a clear thing it leads into u kno what thwe valve ios for and is it bad that i just adjusted the idle?
Old 10-11-2007, 03:08 PM   #4
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
well the only thing bad with messin with the idle screw, is if you dont know what your doing lol
imo, as for the other screw, id suggest getting a new one asap. local hardware store should carry it, just take urs in as a sample
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 10-11-2007, 06:09 PM   #5
ok well i got the idle fixed on my car it stays at 650 now and runs perfect bbut it jumps from running lean to running rich how do i fix that?
Old 10-12-2007, 05:16 AM   #6
f00g00
Did you adjust your idle by adjusting this, the dashpot system?
http://www.turboninjas.com/mk3supra/...ndiv/06_EC.pdf
Blitz MSTT Speed adjustment SunDan MKIII Supra 5 11-17-2009 07:41 AM
Finally, Idle Set! scruffboy Non-Generation Specific Questions 6 01-16-2007 02:39 PM
