Old 10-09-2007, 09:16 PM   #1
ethan12510
ethan12510 is on a distinguished road
Default Really High Idle
ok so my car idles at like 2500 RPMS. But when i put it into gear its fine and drives like normal? The clutch kinda feels funny maybe spongey? Also installed a BOV And reset the EFI by pulling the fuse. Any help would be great.
ethan12510 is offline   Reply With Quote
Old 10-10-2007, 12:04 AM   #2
redmaro
Any check engine codes?
Also did you start having the problem since you installed the bov?
MK3, Auto, Turbo.
Old 10-10-2007, 12:16 AM   #3
ethan12510
the Check engine light isnt on or hasnt blinked so i dont think there are anycodes? I was told the pull the EFI Fuse to have to ECU learn a new Fuel Map or something. I recently bought a used AFM bc mine was going bad and i thought that i might have bought a bad AFM so i sawped the electronics to see if that was the cause and still the car idles at 2500 and will go up like im accelerating to 3000 but im not pushing the gas? I just disconected the battery to reset everything thinking that might help.
Old 10-10-2007, 12:22 AM   #4
redmaro
Check your codes anyways sometimes theyll get stored.
MK3, Auto, Turbo.
Old 10-10-2007, 12:34 AM   #5
ethan12510
alright but what could be causing this? Any ideas?
Old 10-10-2007, 12:39 AM   #6
redmaro
It could be a bunch of stuff, anywhere from a MAF sensor to a simple air leak.
MK3, Auto, Turbo.
Old 10-10-2007, 12:47 AM   #7
ethan12510
u mean a vacume leak? Tommarow im going to look at it, i just need to know what to look for.
Old 10-10-2007, 12:50 AM   #8
redmaro
LOL yeah a vacuum leak, I couldnt think of teh word.
MK3, Auto, Turbo.
Old 10-10-2007, 12:55 AM   #9
ethan12510
Ok, Where should i start? now im leaning towards a boost leak?
http://www.vfaq.com/mods/ICtester.html
will this work
Old 10-10-2007, 03:46 AM   #10
redmaro
Yeah that will work.
heres DIY boost leak detector link from supramania.
http://www.supramania.com/forums/showthread.php?t=19718
MK3, Auto, Turbo.
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
annoying high pitch squeal at idle oowee623 MKIII Supra 2 06-04-2007 03:02 AM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
High idle nickvash0104 MKIII Supra 21 07-13-2006 05:14 AM
