Old 10-06-2007, 09:11 PM   #1
Supra2NR
Supra2NR's Avatar
Default Speed Sensor
where is the speed sensor or sending unit that send the signal to the speedo?
Old 10-07-2007, 12:23 AM   #2
supramacist
supramacist's Avatar
Driver side fire wall.
Old 10-07-2007, 04:11 PM   #3
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
good tip, repair manuals help :P trust me.
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 10-08-2007, 03:31 AM   #4
Supra2NR
Supra2NR's Avatar
i had a haynes manual b4 but i cant find it
Old 10-08-2007, 05:54 AM   #5
86SupraMan
86SupraMan's Avatar
Haynes makes a good manual
86.5 Toyota Supra
((Current Mods)) :
-K&N Filtercharger
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
Old 10-09-2007, 05:11 AM   #6
Supra2NR
Supra2NR's Avatar
any detailed info?
which one is the signal wire, and where exactly is the sensor?
Old 10-09-2007, 12:06 PM   #7
supramacist
It should be coming through the firewall directly behind the instrument panel, or in a bundle from the same area. Hard to say without looking under the hood, but should be fairly obvious.
where and wha color is the speed sensor and rpm signal wire 88Tsupra MKIII Supra 6 03-16-2011 07:48 PM
Engine Speed Sensor BVR1 Non-Generation Specific Questions 1 05-21-2008 12:10 PM
