Old 10-05-2007, 06:18 AM   #1
west_side_supra
west_side_supra's Avatar
Default 550cc
ok so i am upgrading to 550cc injectors, and i was wondering if i needed anything else, like
lexus AFM?
adj. fuel pressure reg?
fuel pump?
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 10-05-2007, 09:12 AM   #2
ddmcse
ddmcse's Avatar
Cool
at the least you need the AFM
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 10-05-2007, 07:35 PM   #3
west_side_supra
k well i'm orderin a new lexus afm, thanks. now will this knock my fuel cut up to about 15lbs of boost
fidenza cam gears
Old 10-05-2007, 09:57 PM   #4
west_side_supra
i just ordered a apexi S-AFC also
fidenza cam gears
Old 10-05-2007, 10:44 PM   #5
justin1642
justin1642's Avatar
justin1642 is on a distinguished road
if i'm not mistaken i read on one of the supra forums that lexus afm and 550's raise fuel cut to 18 psi.
justin1642 is offline   Reply With Quote
Old 10-06-2007, 02:34 AM   #6
supradrift
supradrift is on a distinguished road
all you need is the injectors and the afm. though they say you can go to 18 psi i dont recommend going any higher then 12. beginning of the summer i did the same thing raised it to 15 psi with my boost controller and now im having turbo trouble. so unless you plan on getting another turbo dont go much higher then 12
supradrift is offline   Reply With Quote
Old 10-06-2007, 05:19 AM   #7
west_side_supra
lol
uh sorry to mention this but this is all going on my rebuild im doing, currently my motor isnt even in the car
specs:
block : resurfaced : hot tanked : pressure tested ok
new oil pump drive bearings
stock pistons : forged : heat treated tops : .20 over
stock rods : pulled out and grabed all the best ones
new bearings
new rings
all bolts and studs are ARP
new HKS HG : ARP studs
new Water pump
new oil pump
all new gaskets
TRD oil filter
thermostat and gasket
fidanza Flywheel
stage 3 XTD 6 puck clutch and pressure plate
Head : resurfaced and also EGR cooler plate: Port and polished : hot tanked
stage 1 cams
stainless steel headers with wastegate dump pipe
fidanza adjustable cam gears
stock valve : springs : retainers
Garret T70 Gt46 : Compressor Wheel - .66 A/R, 48.9 trim Turbine Wheel - 1.05 A/R, 61.9 trim 4.25" inlet, 3.38" outlet T4 flange with V-band
50mm wastegate
Magnicore kv-85 8.5 spark plug wires
NGK IRIDIUM XI
RC 550cc injectors /w clips
lexus AFM
Cooleze Turbo inlet
3 inch intercooler pipeing
silicone couplers
hose tecniques hose kit
EGR block off plates
custom 3 inch exhaust : no catalizers : new 02 sensor bunge : v-band
Apexi S-AFC
2 cheap oil filters
15 Q. 10/30 oil
coolant
P/s fluid
lots of brake cleaner
lots of electrical wire in many colors : 16G
and a windsheild wiper
grant steering wheel and hub and quick release
there is probably more
that is about my list of everything i have either already ordered and are waiting on and things that are all done. i'm taking pictures of the rebuild so far and the old motor is out and the new one is being put in probably by next weekend hopefully.
all of the random shit under the hood will be relocated like battery/ignighter/relay box/ect...
all harnesses and connectors are being replaced
all i want to see when i pop the hood is engine and turbo the turbo has a max peak of 35psi and can handle up to 1000 hp. i'll admit its a tad big and may have some clearance issues but as for the wastegate also, i'll make it work. i'm doing this rebuild because of a BHG gone beyond bad. cylinders 6,5 and 3 were blown, bearings where showing signs of being ran low on oil and running really hot, head was cracked and multible oil leaks and the sweet coolant leaks.
but the new goal is building this for a car show sponsered by my college, in the spring time.
so far the total price for everything listed above
$2,358.45
now what do you think i can handle for boost :O and what do you think i will be able to handle power wise
fidenza cam gears
Old 10-06-2007, 05:54 AM   #8
supraman121
why do stock rod? does that mean your doing stock pistons aswell just oversized? you can buy eagle rod for like 480 on sale from suprastore and you can pick up some Wiseco 7MGTE Pistons for like 700 from supra store those have to be better then stock.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 10-06-2007, 07:55 AM   #9
west_side_supra
well see my limit is 2,700. plus again, the pistons are forged and heat treated tops, so they will be better than stock "stronger" and also they are bored .020 over. same as with the rods.
fidenza cam gears
Old 10-08-2007, 11:45 PM   #10
west_side_supra
now has anyone used the turbo headers? the ebay ones? because i have one and i was wondering how much clearance i will have for the wastegate and also my rediculous turbo :P
and also with the apexi S-AFC II gen during the break in process should i just run a 0% +/- then once it has been broken in should i go ahead and tune when i can boost?
how much power do you think i will have with all of these items and also 18psi?
and does anyone know where the EGR block off plates go? i know that i have the 2 intake block offs not the one that goes onto the EGR cooler exhaust side and the other on the intake. From what i understand there is one that goes on the upper intake then the other goes onto the lower
last but not least how long should i break the pooper in for? because i keep getting ranged from 1,000 miles to 10,000 miles, and just for a little more information a tourqe plate wasnt used when boreing it.
oh and found some bad news on the stock turbo, not only was the turbo seal bad and squirting oil all over the place, the bearings were done, and also there was a huge crack by the wastegate that went all the way trough, its SICK!!! :P but i guess thats why i got a new turbo
fidenza cam gears
550cc injectors frostburn MKIII Supra 1 08-18-2008 04:46 AM
550cc and lexus afm supradrift MKIII Supra 2 07-02-2007 10:58 AM
550cc rx7 high impedance injectors? Suppra Girl? rnoswal MKIII Supra 9 05-03-2006 01:36 PM
