Old 10-02-2007, 04:43 PM   #1
Dejvid1785
Dejvid1785 is on a distinguished road
Default Idling Problem!
Me and my buddy did work on his 89 supra and we're having an idling prob. We redid the headgasket, upgraded his ct-26 to a 60-1 trim. Port and polished the head, NA cams, 550 injectors with the lexus afm, 250 walbro fuel pump, 3 inch downpipe, full 3inch exhaust with no cat, aftermarket intercooler with piping, greddy boost controller, safc II. Now we can't get it tuned because the idling keeps jumping from 900 to 1400 it wont stand still so therefore we can't get it tuned. We rejected all the wiring and all the grounds, and we checked the timing three 3 times its dead on. Can anybody help us out, i'm sure someone has run into the same prob. Any help is appreciated, thanx.
88 Targa: Exhaust, Headers, Intake
Dejvid1785 is offline   Reply With Quote
Old 10-02-2007, 05:21 PM   #2
abhattan
abhattan's Avatar
abhattan is on a distinguished road
I think you should check and test the ECT sensor. Also, did you put both NA cams in?
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 10-02-2007, 05:24 PM   #3
redmaro
Any codes?
MK3, Auto, Turbo.
Old 10-02-2007, 09:59 PM   #4
Dejvid1785
Yea we put both cams in, i'll check on the codes and let you know. Can't remember if there was any.
Old 10-02-2007, 10:06 PM   #5
PanzerAce
PanzerAce is on a distinguished road
as a point of interest, when was the fuel filter last changed? If it is plugged up, depending on how the computer is coded, it could be causing your problem.
PanzerAce is offline   Reply With Quote
Old 10-02-2007, 11:51 PM   #6
redmaro
Lets not jump to any conclusions till we get his codes. People be patient.
MK3, Auto, Turbo.
Old 10-03-2007, 01:12 AM   #7
Dejvid1785
It came up with code 51 and 24 if i'm not mistaken. Any idea?
Old 10-03-2007, 01:13 AM   #8
Dejvid1785
And what exactly is the ECT sensor, i know what the TPS sensor is but i've never heard of the ECT sensor.
Old 10-03-2007, 05:08 AM   #9
redmaro
Smile
code 24
Its your INTAKE AIR TEMP SENSOR which is integrated with your Mass Air Flow sensor, its located right after the air filter housing. So your have to buy the whole mass air flow sensor(or it could be the wiring). The MAF costs around $350-$400 brand new. But you could also look in ebay and get a used one, thats what I did. Or go to supramania.com and post in the wanted section.
MK3, Auto, Turbo.
Old 10-03-2007, 05:11 AM   #10
redmaro
Check the link for Code 51
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=28
By what code 51 says, it could also be your TPS which may not be calibrated correctly, your wiring, or the TPS itself. The TPS costs like $110.
MK3, Auto, Turbo.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
Nissan Sentra Tranny problem. redmaro Off Topic Forum 2 11-28-2006 01:58 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
