Old 09-25-2007, 02:44 AM   #1
west_side_supra
west_side_supra's Avatar
Default new turbo
ok so i have got a new turbo ordered
specs
greddy GT 45
Compressor Wheel - .66 A/R, 48.9 trim Turbine Wheel - 1.05 A/R, 61.9 trim 4.25" inlet, 3.38" outlet T4 flange with V-band
now i have a question about the v-band, since its not a straight bolt up to the DP what would i have to do to get it attached, do i just cut off the DP flange and put a v-band adaptor and get a v-band clamp? heres a picture
so what you all think, i'm also getting the aftermarket headers w/ 40-50mm wasgate flange and t4 flange. peak boost for this turbo is 35psi max 600hp
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 09-25-2007, 04:25 AM   #2
Supra2NR
Supra2NR's Avatar
jus get a new 3" downpipe, it will make ur life so much easier
for the meantime you can jus get a flange to bolt it with the rest of the stock exhaust piping,
so when you get some more funds, finish up the whole exhuast with 3" piping
that will jus easily connect and bolt up to the downpipe
Old 09-25-2007, 05:15 AM   #3
west_side_supra
uh i already have 3inch eveything
3inch defcon DP with the 4 bolt flange
3inch DP back no cats
fidenza cam gears
Old 09-26-2007, 06:47 AM   #4
Supra2NR
Supra2NR's Avatar
sorry kinda hasty post i did earlier, i almost got caught at work lol
but what i meant to say was,
i thought u still had to stock downpipe
so u can jus cut off the old flange, and weld the v-band flange on the dowpipe
and connect it to the turbo, should be that simple
Old 09-26-2007, 07:00 PM   #5
west_side_supra
sweet thanks
fidenza cam gears
