Old 09-23-2007, 10:14 AM   #1
the ghoul
the ghoul is on a distinguished road
Default NA cams in a 7mgTe?
Just ran across some one trying to sell 7mge cams.
they said that 7mge cams in a 7mgte will give you a horse power increase of 25-40hp...
Is this true?
if so, do you need to run higher octain?
if any one has info please tell!!
the ghoul is offline   Reply With Quote
Old 09-23-2007, 03:05 PM   #2
OfnaRcR
OfnaRcR is on a distinguished road
Is this true?
Its not true.
Search.
OfnaRcR is offline   Reply With Quote
Old 09-23-2007, 05:14 PM   #3
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
The intake camshaft stays open longer by 10 degrees iirc but the exhaust camshaft is the same. It is not that much more horse power but I think it was a little more but not that much.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Old 09-23-2007, 07:35 PM   #4
Syris
Syris is on a distinguished road
Its more of a torque gain in the lower RPMS
Syris is offline   Reply With Quote
Old 09-23-2007, 08:55 PM   #5
the ghoul
Yeps, thats what I was looking at but I didnt want to post the link because I was thinking of buying it....
if its some increase It might just be worth the $30. I was just looking for quick cheap and easy way to get a little more power, while I was doing my head gasket.
Check this out on ebay. I think that is what you are talking about
Old 09-23-2007, 08:56 PM   #6
the ghoul
Originally Posted by OfnaRcR
Its not true.
Search.
I search, and came up with nothing, thats why I posted...
just came up with close to a real answer and the tread ends with people say "do a search" (you see where the system brakes down?)
Old 09-24-2007, 04:27 AM   #7
Syris
Cams in general are more of moving the powerband around.
Old 09-24-2007, 10:02 PM   #8
the ghoul
great genral knowlage... now how does it apply?
what does the NA cams do for the turbo engine?
lower the power band so you have more lower end 'grunt'?
Old 09-25-2007, 04:49 AM   #9
Syris
Well ovbiously if you wouldve read my posts earlier in this thread I already stated what it does on the turbo engine....
Old 09-25-2007, 05:52 AM   #10
teedoff00
teedoff00's Avatar
teedoff00 is on a distinguished road
From what I have research, na cams in your 7m-gte are good for a few ft/lbs and even some horse power, but they wont withstand the abuse if you are running alot of boost or are aiming to hit high numbers, ie. over 300-350 horse. So if you are pretty much stock, then you will probably notice a nice increase, if you are looking for a reliable high horse power build stay away. Also make sure the cams are in good shape or you might risk jacking your valves as well as you guides, that could get pricey...
teedoff00 is offline   Reply With Quote
88 7mgte styock cams wanted mine are bad badassbob Non-Generation Specific Questions 0 07-06-2008 08:46 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
na cams on a 7mgte noa324 MKIII Supra 0 09-04-2006 12:11 AM
JDM 7MGTE vs. Amercan cams berniek MKIII Supra 0 01-21-2006 08:32 AM
