Old 09-12-2007, 08:11 AM   #1
furia
furia is on a distinguished road
Default Oil burning
My supra smells like burnt oil. Now there is no black smoke coming out of the back. Also I must mention that the head was recently done. I would do a compression test but I cant get my tester untill the weekend(fuck borrowing stuff) and the burnt oil smell is going to give me sleepless nights untill then.
What I find wierd is that whener I top up the oil A LOT of black smoke(oil) comes out of my tailpipe. After a few mins it goes away. I notice there is a hose comming from right underneath the oil fill hole. Is that where the PCV valve should be? I wonder if oil is just thrown out in that hose. What is that hose anyways?
Also worth mentioning is that I use the Castrol syntetic 10w40 with 3 quarters of a bottle Lucas syntetic aditive. My oil pressure at highway speed is at 4.
furia is offline   Reply With Quote
Old 09-12-2007, 08:16 AM   #2
redmaro
Black smoke isnt oil.
MK3, Auto, Turbo.
Old 09-12-2007, 08:19 AM   #3
furia
Whops yes thats gas leaking, none of that. I mean to say dark-bluish deff the oil kind.
Old 09-12-2007, 02:21 PM   #4
mrnickleye
mrnickleye's Avatar
4psi is low at hwy speed, but normal at idle.
blue (ish) smoke is oil.
the hose is there to link (air vapor wise) the block to the top end. leave it alone.
the pcv system has no valve. the 2 hoses come off the valve covers and "Y" into the throttlebody. see the FAQs section for proceedures to clean that out so it works right.
http://www.toyota-supra.info/forums/...ead.php?t=7930
Old 09-12-2007, 03:58 PM   #5
furia
Oil pressure is 4 kg/cm^2 which translates to 57 PSI.
So I guess I will just have to wait to do my compression test and see where I am going from there.
Old 09-13-2007, 03:57 AM   #6
mrnickleye
mrnickleye's Avatar
A compression test may be pretty good, and you could still have some bad oil rings on a piston or 2. That can let it smoke, and still run good, until a spark plug fouls. Pull all the plugs and check them for oil contamination.
Old 09-13-2007, 04:03 AM   #7
furia
In the end I think it is actually a leaking injector that produces the smell. I bought a new compression tester and everything came out within specs. One plug looks washed by gas and I can actually hear one injector leaking. My fuel pump does not stop running so I am positive now that one injector is leaking. I supose a leaking injector would create a wierd smell.
Old 09-13-2007, 02:04 PM   #8
mrnickleye
mrnickleye's Avatar
Yes it will (smell). And....after you repair it (very soon), better change the motor oil, as it will be full of fuel.
At the shop, we like to use new injector when the customer isn't a tight wad, because rebuilts can have problems, now or sooner than a new one.
Old 09-13-2007, 08:36 PM   #9
furia
I just got a complete(6) set of brand new injectors off ebay.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...0%3D%26fvi%3D1
Is that a decent brand?
Old 09-15-2007, 04:36 AM   #10
mrnickleye
mrnickleye's Avatar
Haven't heard of that brand. probably China. Let us know how the work out. They might work fine.
At my shop, we only use new, because remans fail to much.
burning oil why??? ebang MKIII Supra 11 12-06-2010 05:59 AM
burning oil please help cyanide-is-a-way-out MKIII Supra 10 10-31-2007 10:02 PM
whats burning?! sd88supra MKIII Supra 4 07-26-2007 07:01 PM
Burning Oil Smell nightreaper Non-Generation Specific Questions 3 09-01-2006 09:34 AM
Burning rich need supra help brad mccarty MKIII Supra 6 02-12-2006 08:49 PM
