Old 09-08-2007, 02:50 PM   #1
natedogg89supra
natedogg89supra is on a distinguished road
Default How hard is would this be?
Well as a few of you know I am new in the supra scene and just bought a mk3...the biggest thing im not liking about it is that its a automatic so my question is how hard would it be to find a 5spd trans and all the other stuff I would need to do a auto to 5spd swap. (in the chicago area) I dont know the area very well because i just moved here so i dont know where any salvage yards are. Any help is greatly appreciated.
natedogg89supra is offline   Reply With Quote
Old 09-08-2007, 07:53 PM   #2
Syris
Syris is on a distinguished road
well have you ever rebuilt an engine before? Have you ever swapped a transmission before? If not dont attempt it
Syris is offline   Reply With Quote
Old 09-08-2007, 07:55 PM   #3
natedogg89supra
yes i have, i guess more along the lines of my question is how hard is it to find a good supra tranny in like a salvage yard
Old 09-09-2007, 01:17 AM   #4
Jeff_5_7
Jeff_5_7's Avatar
Jeff_5_7 is on a distinguished road
i did the auto to 5sp swap me and my brother did it all in a weekend but i had a parts car that had all the five speed stuff if i was u i would check ebay or craigslist for the stuff u need the
clutch pedal assemby
master cylinder
slave cylinder
clutch lines
drive shaft
and a clutch and flywheel
and the shifter i think thats all u will need in case u needed to no what to look for
Supras anrt ricers there Japanese Muscle
1988 supra n/a just finsihed 5 speed swap
goal is 400hp with a turbo motor swap
Jeff_5_7 is offline   Reply With Quote
Old 09-09-2007, 06:20 AM   #5
oowee623
oowee623's Avatar
hard part, getting the auto out, easy part getting the 5 speed in, but altogether not that hard just a lot of strength, youll need a new speedo cable, clutch master/slave cylinder, clutch line, clutch and brake pedals, tranny driveshaft, flywheel, clutch, pressure plate, pilot bearing, release bearing, driver side wing bracket, inspection plate, 6 new flywheel bolts beginner wiring skills, and tach and ecu (last two are optional)
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
how hard are they bleSId MKII Supra 1 06-29-2007 06:44 PM
Hard Shifting in Automatic. redmaro MKIII Supra 2 05-18-2007 04:08 AM
hard wireing hks vpc to mkiv mikey2jz MKIV Supra 1 02-23-2006 03:04 PM
replacing head gasket,how hard? supradex Non-Generation Specific Questions 1 12-09-2005 02:00 PM
How hard to do a Auto to manual conversion? lOnEstArMx250r Non-Generation Specific Questions 1 10-14-2005 08:14 PM
