Old 09-05-2007, 03:51 PM   #1
toyosuprastl
toyosuprastl is on a distinguished road
Default break lights won't turn off
i've asked around, had break light switches replaced, the little box in the back replaced, ground wires replaced, all types of things
and the break lights on the car just won't turn off. you start the car, and they staty on, lit (high intensity), so when ur driving it's showing as if u were breaking, u can turn the car off, and the lights still remain lit, unless you unplug them, it's the break lights btw, can any1 help me out?
btw it's a 91
toyosuprastl is offline   Reply With Quote
Old 09-05-2007, 05:24 PM   #2
phill_54321
phill_54321 is on a distinguished road
i had the same problem. if you follow the break peddle up you will find a small button. you can adjust the button and your lights will turn off.
phill_54321 is offline   Reply With Quote
Old 09-22-2007, 08:26 PM   #3
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
It's possible the little button he's describing has broken off. I had that problem recently and to fix it I got a plastic press fit rivet to go in the hole to make up for the gap the old button would fill in between the brake arm and the brake light off sensor. Do some back stretches and get a bright flashlight to look under your dash to see what we are describing.
Drag0na5h is offline   Reply With Quote
Old 09-26-2007, 01:26 PM   #4
ethan12510
ethan12510 is on a distinguished road
check brake fluid level?
ethan12510 is offline   Reply With Quote
Old 09-27-2007, 07:32 AM   #5
supraman121
Umm this might be dumb but what does the brake fluid lvl have anything to do with the lights staying on? Well let me refrase if your brake fluid is low it might cause the pedal to sink i guess and cause it to activate the brake lights, iv never heard of it happing tho.
Anyway did you replace the switch that tells the car that the brake pedal is being pushed? I dont know were it is, but if heard of it happening to some people it was a simple case of it was bad and sticking.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 09-27-2007, 08:31 PM   #6
carfanatic89
carfanatic89's Avatar
Post
the same thing happend to me its more than likely the switch infront of the brake pedal. when you press on the brakes it lets the switch go out completing the circuit and turns the light on if its miss adjusted than the pedal wont press it in to tell the lights to turn off.
Supra Engine Powered Dragster
Old 09-27-2007, 10:09 PM   #7
ethan12510
when the fluid is low the light will come on
Old 09-27-2007, 10:43 PM   #8
carfanatic89
the original thread was talking about his brake light outside the car not the on in the dash
Break lights on... ~*B Magical*~ MKIII Supra 3 03-01-2008 12:27 AM
Clear Corner (Turn signal) Lights ??? jdbones Non-Generation Specific Questions 2 11-01-2007 04:41 AM
Instument Cluster and Back lights don't turn on! Paulv95123 MKIII Supra 9 06-12-2006 11:21 AM
